What’s the point for them? Virtually, your kernel is the only program run on GPU, so it can hold the whole global memory. Declaring variables statically would be faster.
The point is that if I use the whole global memory I have to write an own memory management functionality to manage the fragments that i use an release inside the kernel.
In my special case I have such like an arrayList on global memory that can be full, after that i have to resize it (on device).
And I don’t have just one, maybe every thread has its arrayList, so if I just continue writing out of bounds I may write into an other arrayList and crash it.
And just allocating a huge amount of memory for each list is not a solution, because its waste of resources and even a huge array may be too small, even if there is unused memory inside another arrayList.
