Mask_rcnn deployment failed in NX, oom error
• Hardware jetson NX, jetpack 4.6
• Network Type Mask_rcnn
• TLT Version 4.0
• tao-converter Version v3.21.11_trt8.0_aarch64
The state of jtop before the conversion:
My command:
./tao-converter -k nvidia_tlt  -d 3,1344,1344 -e ./trt.fp16.engine -t fp16 -o generate_detections,mask_fcn_logits/BiasAdd ./model.step-255710.etlt
Error info:
[INFO] [MemUsageChange] Init CUDA: CPU +354, GPU +0, now: CPU 372, GPU 4386 (MiB)
[INFO] [MemUsageSnapshot] Builder begin: CPU 730 MiB, GPU 4861 MiB
[INFO] ---------- Layers Running on DLA ----------
[INFO] ---------- Layers Running on GPU ----------
[INFO] [GpuLayer] conv1/Conv2D + activation/Relu
[INFO] [GpuLayer] max_pooling2d/MaxPool
[INFO] [GpuLayer] block_1a_conv_1/Conv2D + block_1a_relu_1/Relu
[INFO] [GpuLayer] block_1a_conv_2/Conv2D + block_1a_relu_2/Relu
[INFO] [GpuLayer] block_1a_conv_shortcut/Conv2D
[INFO] [GpuLayer] block_1a_conv_3/Conv2D + add/add + block_1a_relu/Relu
[INFO] [GpuLayer] block_1b_conv_1/Conv2D + block_1b_relu_1/Relu
[INFO] [GpuLayer] block_1b_conv_2/Conv2D + block_1b_relu_2/Relu
[INFO] [GpuLayer] block_1b_conv_3/Conv2D + add_1/add + block_1b_relu/Relu
[INFO] [GpuLayer] block_1c_conv_1/Conv2D + block_1c_relu_1/Relu
[INFO] [GpuLayer] block_1c_conv_2/Conv2D + block_1c_relu_2/Relu
[INFO] [GpuLayer] block_1c_conv_3/Conv2D + add_2/add + block_1c_relu/Relu
[INFO] [GpuLayer] block_2a_conv_1/Conv2D + block_2a_relu_1/Relu
[INFO] [GpuLayer] block_2a_conv_2/Conv2D + block_2a_relu_2/Relu
[INFO] [GpuLayer] block_2a_conv_shortcut/Conv2D
[INFO] [GpuLayer] block_2a_conv_3/Conv2D + add_3/add + block_2a_relu/Relu
[INFO] [GpuLayer] block_2b_conv_1/Conv2D + block_2b_relu_1/Relu
[INFO] [GpuLayer] block_2b_conv_2/Conv2D + block_2b_relu_2/Relu
[INFO] [GpuLayer] block_2b_conv_3/Conv2D + add_4/add + block_2b_relu/Relu
[INFO] [GpuLayer] block_2c_conv_1/Conv2D + block_2c_relu_1/Relu
[INFO] [GpuLayer] block_2c_conv_2/Conv2D + block_2c_relu_2/Relu
[INFO] [GpuLayer] block_2c_conv_3/Conv2D + add_5/add + block_2c_relu/Relu
[INFO] [GpuLayer] block_2d_conv_1/Conv2D + block_2d_relu_1/Relu
[INFO] [GpuLayer] block_2d_conv_2/Conv2D + block_2d_relu_2/Relu
[INFO] [GpuLayer] block_2d_conv_3/Conv2D + add_6/add + block_2d_relu/Relu
[INFO] [GpuLayer] block_3a_conv_1/Conv2D + block_3a_relu_1/Relu
[INFO] [GpuLayer] block_3a_conv_2/Conv2D + block_3a_relu_2/Relu
[INFO] [GpuLayer] block_3a_conv_shortcut/Conv2D
[INFO] [GpuLayer] block_3a_conv_3/Conv2D + add_7/add + block_3a_relu/Relu
[INFO] [GpuLayer] block_3b_conv_1/Conv2D + block_3b_relu_1/Relu
[INFO] [GpuLayer] block_3b_conv_2/Conv2D + block_3b_relu_2/Relu
[INFO] [GpuLayer] block_3b_conv_3/Conv2D + add_8/add + block_3b_relu/Relu
[INFO] [GpuLayer] block_3c_conv_1/Conv2D + block_3c_relu_1/Relu
[INFO] [GpuLayer] block_3c_conv_2/Conv2D + block_3c_relu_2/Relu
[INFO] [GpuLayer] block_3c_conv_3/Conv2D + add_9/add + block_3c_relu/Relu
[INFO] [GpuLayer] block_3d_conv_1/Conv2D + block_3d_relu_1/Relu
[INFO] [GpuLayer] block_3d_conv_2/Conv2D + block_3d_relu_2/Relu
[INFO] [GpuLayer] block_3d_conv_3/Conv2D + add_10/add + block_3d_relu/Relu
[INFO] [GpuLayer] block_3e_conv_1/Conv2D + block_3e_relu_1/Relu
[INFO] [GpuLayer] block_3e_conv_2/Conv2D + block_3e_relu_2/Relu
[INFO] [GpuLayer] block_3e_conv_3/Conv2D + add_11/add + block_3e_relu/Relu
[INFO] [GpuLayer] block_3f_conv_1/Conv2D + block_3f_relu_1/Relu
[INFO] [GpuLayer] block_3f_conv_2/Conv2D + block_3f_relu_2/Relu
[INFO] [GpuLayer] block_3f_conv_3/Conv2D + add_12/add + block_3f_relu/Relu
[INFO] [GpuLayer] block_4a_conv_1/Conv2D + block_4a_relu_1/Relu
[INFO] [GpuLayer] block_4a_conv_2/Conv2D + block_4a_relu_2/Relu
[INFO] [GpuLayer] block_4a_conv_shortcut/Conv2D
[INFO] [GpuLayer] block_4a_conv_3/Conv2D + add_13/add + block_4a_relu/Relu
[INFO] [GpuLayer] block_4b_conv_1/Conv2D + block_4b_relu_1/Relu
[INFO] [GpuLayer] block_4b_conv_2/Conv2D + block_4b_relu_2/Relu
[INFO] [GpuLayer] block_4b_conv_3/Conv2D + add_14/add + block_4b_relu/Relu
[INFO] [GpuLayer] block_4c_conv_1/Conv2D + block_4c_relu_1/Relu
[INFO] [GpuLayer] block_4c_conv_2/Conv2D + block_4c_relu_2/Relu
[INFO] [GpuLayer] block_4c_conv_3/Conv2D + add_15/add + block_4c_relu/Relu
[INFO] [GpuLayer] l5/Conv2D
[INFO] [GpuLayer] nearest_upsampling_2
[INFO] [GpuLayer] l4/Conv2D + FPN_add_4/add
[INFO] [GpuLayer] nearest_upsampling_1
[INFO] [GpuLayer] l3/Conv2D + FPN_add_3/add
[INFO] [GpuLayer] l2/Conv2D + FPN_add_2/add
[INFO] [GpuLayer] post_hoc_d2/Conv2D
[INFO] [GpuLayer] rpn/Conv2D + rpn/Relu
[INFO] [GpuLayer] rpn-box/Conv2D || rpn-class/Conv2D
[INFO] [GpuLayer] (Unnamed Layer* 475) [Shuffle] + MLP/multilevel_propose_rois/level_2/Reshape_1
[INFO] [GpuLayer] (Unnamed Layer* 483) [Shuffle] + MLP/multilevel_propose_rois/level_2/Reshape
[INFO] [GpuLayer] PWN(MLP/multilevel_propose_rois/level_2/Sigmoid)
[INFO] [GpuLayer] post_hoc_d3/Conv2D
[INFO] [GpuLayer] rpn_1/Conv2D + rpn_1/Relu
[INFO] [GpuLayer] rpn-box_1/Conv2D || rpn-class_1/Conv2D
[INFO] [GpuLayer] (Unnamed Layer* 497) [Shuffle] + MLP/multilevel_propose_rois/level_3/Reshape_1
[INFO] [GpuLayer] (Unnamed Layer* 503) [Shuffle] + MLP/multilevel_propose_rois/level_3/Reshape
[INFO] [GpuLayer] PWN(MLP/multilevel_propose_rois/level_3/Sigmoid)
[INFO] [GpuLayer] post_hoc_d4/Conv2D
[INFO] [GpuLayer] rpn_2/Conv2D + rpn_2/Relu
[INFO] [GpuLayer] rpn-box_2/Conv2D || rpn-class_2/Conv2D
[INFO] [GpuLayer] (Unnamed Layer* 517) [Shuffle] + MLP/multilevel_propose_rois/level_4/Reshape_1
[INFO] [GpuLayer] (Unnamed Layer* 523) [Shuffle] + MLP/multilevel_propose_rois/level_4/Reshape
[INFO] [GpuLayer] PWN(MLP/multilevel_propose_rois/level_4/Sigmoid)
[INFO] [GpuLayer] post_hoc_d5/Conv2D
[INFO] [GpuLayer] rpn_3/Conv2D + rpn_3/Relu
[INFO] [GpuLayer] rpn-box_3/Conv2D || rpn-class_3/Conv2D
[INFO] [GpuLayer] (Unnamed Layer* 537) [Shuffle] + MLP/multilevel_propose_rois/level_5/Reshape_1
[INFO] [GpuLayer] (Unnamed Layer* 543) [Shuffle] + MLP/multilevel_propose_rois/level_5/Reshape
[INFO] [GpuLayer] PWN(MLP/multilevel_propose_rois/level_5/Sigmoid)
[INFO] [GpuLayer] p6/MaxPool
[INFO] [GpuLayer] rpn_4/Conv2D + rpn_4/Relu
[INFO] [GpuLayer] rpn-box_4/Conv2D || rpn-class_4/Conv2D
[INFO] [GpuLayer] (Unnamed Layer* 554) [Shuffle] + MLP/multilevel_propose_rois/level_6/Reshape_1
[INFO] [GpuLayer] (Unnamed Layer* 560) [Shuffle] + MLP/multilevel_propose_rois/level_6/Reshape
[INFO] [GpuLayer] PWN(MLP/multilevel_propose_rois/level_6/Sigmoid)
[INFO] [GpuLayer] multilevel_propose_rois
[INFO] [GpuLayer] pyramid_crop_and_resize_box
[INFO] [GpuLayer] shuffle_between_pyramid_crop_and_resize_box_and_fc6/MatMul
[INFO] [GpuLayer] fc6/MatMul + fc6/Relu
[INFO] [GpuLayer] fc7/MatMul + fc7/Relu
[INFO] [GpuLayer] box-predict/MatMul
[INFO] [GpuLayer] class-predict/MatMul
[INFO] [GpuLayer] box_head_softmax
[INFO] [GpuLayer] generate_detections
[INFO] [GpuLayer] mrcnn_detection_bboxes
[INFO] [GpuLayer] pyramid_crop_and_resize_mask
[INFO] [GpuLayer] mask-conv-l0/Conv2D + mask-conv-l0/Relu
[INFO] [GpuLayer] mask-conv-l1/Conv2D + mask-conv-l1/Relu
[INFO] [GpuLayer] mask-conv-l2/Conv2D + mask-conv-l2/Relu
[INFO] [GpuLayer] mask-conv-l3/Conv2D + mask-conv-l3/Relu
[INFO] [GpuLayer] (Unnamed Layer* 623) [Deconvolution] + conv5-mask/conv2d_transpose + conv5-mask/BiasAdd + conv5-mask/Relu
[INFO] [GpuLayer] mask_fcn_logits/Conv2D
[INFO] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +226, GPU +200, now: CPU 1053, GPU 5062 (MiB)
[INFO] [MemUsageChange] Init cuDNN: CPU +307, GPU +310, now: CPU 1360, GPU 5372 (MiB)
[WARNING] Detected invalid timing cache, setup a local cache instead
[ERROR] Tactic Device request: 1545MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 0 due to oom error on requested size of 1545 detected for tactic 0.
[ERROR] Tactic Device request: 1548MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 1 due to oom error on requested size of 1548 detected for tactic 1.
[ERROR] Tactic Device request: 1551MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 3 due to oom error on requested size of 1551 detected for tactic 5.
[WARNING] Skipping tactic 4 due to oom error on requested size of 1545 detected for tactic 56.
[WARNING] Skipping tactic 5 due to oom error on requested size of 1548 detected for tactic 57.
[WARNING] Skipping tactic 7 due to oom error on requested size of 1551 detected for tactic 61.
[INFO] Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
[ERROR] Tactic Device request: 1764MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 0 due to oom error on requested size of 1764 detected for tactic 1002.
[WARNING] Skipping tactic 1 due to oom error on requested size of 1764 detected for tactic 0.
[WARNING] Internal error: cannot reformat, disabling format. Try decreasing the workspace size with IBuilderConfig::setMaxWorkspaceSize().
[WARNING] Memory requirements of format conversion cannot be satisfied during timing, format rejected.
[ERROR] Tactic Device request: 1987MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 0 due to oom error on requested size of 1987 detected for tactic -1.
[ERROR] Tactic Device request: 1819MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 0 due to oom error on requested size of 1819 detected for tactic 0.
[WARNING] Skipping tactic 1 due to oom error on requested size of 1819 detected for tactic 1.
[ERROR] Tactic Device request: 2039MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 2 due to oom error on requested size of 2039 detected for tactic 2.
[WARNING] Skipping tactic 4 due to oom error on requested size of 1819 detected for tactic 56.
[WARNING] Skipping tactic 5 due to oom error on requested size of 1819 detected for tactic 57.
[WARNING] Skipping tactic 6 due to oom error on requested size of 2039 detected for tactic 58.
[WARNING] Skipping tactic 0 due to oom error on requested size of 1819 detected for tactic 1754569683116234317.
[WARNING] Skipping tactic 1 due to oom error on requested size of 1819 detected for tactic 1825138533642645384.
[WARNING] Skipping tactic 2 due to oom error on requested size of 1819 detected for tactic 2733356012094739613.
[WARNING] Skipping tactic 3 due to oom error on requested size of 1819 detected for tactic 3915320020053085238.
[WARNING] Skipping tactic 4 due to oom error on requested size of 1819 detected for tactic 6808617066150061604.
[WARNING] Skipping tactic 5 due to oom error on requested size of 1819 detected for tactic 9091006216302412844.
[WARNING] Skipping tactic 6 due to oom error on requested size of 1819 detected for tactic -8060443123034038864.
[WARNING] Skipping tactic 7 due to oom error on requested size of 1819 detected for tactic -4420849921117327522.
[WARNING] Skipping tactic 8 due to oom error on requested size of 1819 detected for tactic -3946921629105938337.
[WARNING] Skipping tactic 0 due to oom error on requested size of 1819 detected for tactic 861694390046228376.
[WARNING] Skipping tactic 1 due to oom error on requested size of 1819 detected for tactic 5258189349241541167.
[WARNING] Skipping tactic 2 due to oom error on requested size of 1819 detected for tactic 5821621277990374316.
[WARNING] Skipping tactic 3 due to oom error on requested size of 1819 detected for tactic 5863767799113001648.
[WARNING] Skipping tactic 4 due to oom error on requested size of 1819 detected for tactic -9147980667639709536.
[WARNING] Skipping tactic 5 due to oom error on requested size of 1819 detected for tactic -8892196987859366827.
[WARNING] Skipping tactic 6 due to oom error on requested size of 1819 detected for tactic -8850904373104590857.
[WARNING] Skipping tactic 7 due to oom error on requested size of 1819 detected for tactic -8010679767156598961.
[WARNING] Skipping tactic 8 due to oom error on requested size of 1819 detected for tactic -7751035352149795660.
[WARNING] Skipping tactic 9 due to oom error on requested size of 1819 detected for tactic -5115676123557684531.
[WARNING] Skipping tactic 10 due to oom error on requested size of 1819 detected for tactic -493597327599791285.
[WARNING] Skipping tactic 11 due to oom error on requested size of 1819 detected for tactic -423878181466897819.
[WARNING] Skipping tactic 2 due to oom error on requested size of 1819 detected for tactic 2.
[WARNING] Skipping tactic 4 due to oom error on requested size of 1819 detected for tactic 58.
[ERROR] Tactic Device request: 3197MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 0 due to oom error on requested size of 3197 detected for tactic 1002.
[WARNING] Skipping tactic 1 due to oom error on requested size of 3197 detected for tactic 0.
[ERROR] Tactic Device request: 2397MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 0 due to oom error on requested size of 2397 detected for tactic 1002.
[WARNING] Skipping tactic 1 due to oom error on requested size of 2397 detected for tactic 0.
[ERROR] Tactic Device request: 1598MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 0 due to oom error on requested size of 1598 detected for tactic 1002.
[WARNING] Skipping tactic 1 due to oom error on requested size of 1598 detected for tactic 0.
[ERROR] Tactic Device request: 3528MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 0 due to oom error on requested size of 3528 detected for tactic 0.
[WARNING] Skipping tactic 1 due to oom error on requested size of 3528 detected for tactic 1.
[ERROR] Tactic Device request: 3858MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 2 due to oom error on requested size of 3858 detected for tactic 2.
[WARNING] Skipping tactic 4 due to oom error on requested size of 3528 detected for tactic 56.
[WARNING] Skipping tactic 5 due to oom error on requested size of 3528 detected for tactic 57.
[WARNING] Skipping tactic 6 due to oom error on requested size of 3858 detected for tactic 58.
[WARNING] Skipping tactic 0 due to oom error on requested size of 3528 detected for tactic 1754569683116234317.
[WARNING] Skipping tactic 1 due to oom error on requested size of 3528 detected for tactic 1825138533642645384.
[WARNING] Skipping tactic 2 due to oom error on requested size of 3528 detected for tactic 2733356012094739613.
[WARNING] Skipping tactic 3 due to oom error on requested size of 3528 detected for tactic 3915320020053085238.
[WARNING] Skipping tactic 4 due to oom error on requested size of 3528 detected for tactic 6808617066150061604.
[WARNING] Skipping tactic 5 due to oom error on requested size of 3528 detected for tactic 9091006216302412844.
[WARNING] Skipping tactic 6 due to oom error on requested size of 3528 detected for tactic -8060443123034038864.
[WARNING] Skipping tactic 7 due to oom error on requested size of 3528 detected for tactic -4420849921117327522.
[WARNING] Skipping tactic 8 due to oom error on requested size of 3528 detected for tactic -3946921629105938337.
[WARNING] Skipping tactic 0 due to oom error on requested size of 3528 detected for tactic 861694390046228376.
[WARNING] Skipping tactic 1 due to oom error on requested size of 3528 detected for tactic 5258189349241541167.
[WARNING] Skipping tactic 2 due to oom error on requested size of 3528 detected for tactic 5821621277990374316.
[WARNING] Skipping tactic 3 due to oom error on requested size of 3528 detected for tactic 5863767799113001648.
[WARNING] Skipping tactic 4 due to oom error on requested size of 3528 detected for tactic -9147980667639709536.
[WARNING] Skipping tactic 5 due to oom error on requested size of 3528 detected for tactic -8892196987859366827.
[WARNING] Skipping tactic 6 due to oom error on requested size of 3528 detected for tactic -8850904373104590857.
[WARNING] Skipping tactic 7 due to oom error on requested size of 3528 detected for tactic -8010679767156598961.
[WARNING] Skipping tactic 8 due to oom error on requested size of 3528 detected for tactic -7751035352149795660.
[WARNING] Skipping tactic 9 due to oom error on requested size of 3528 detected for tactic -5115676123557684531.
[WARNING] Skipping tactic 10 due to oom error on requested size of 3528 detected for tactic -493597327599791285.
[WARNING] Skipping tactic 11 due to oom error on requested size of 3528 detected for tactic -423878181466897819.
[WARNING] Skipping tactic 0 due to oom error on requested size of 1764 detected for tactic 0.
[WARNING] Skipping tactic 1 due to oom error on requested size of 1764 detected for tactic 1.
[ERROR] Tactic Device request: 1929MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 2 due to oom error on requested size of 1929 detected for tactic 2.
[WARNING] Skipping tactic 4 due to oom error on requested size of 1764 detected for tactic 56.
[WARNING] Skipping tactic 5 due to oom error on requested size of 1929 detected for tactic 58.
[WARNING] Skipping tactic 0 due to oom error on requested size of 1764 detected for tactic 2418518597804310654.
[WARNING] Skipping tactic 1 due to oom error on requested size of 1764 detected for tactic 8292881859266835088.
[WARNING] Skipping tactic 2 due to oom error on requested size of 1764 detected for tactic 8401509141903434922.
[WARNING] Skipping tactic 3 due to oom error on requested size of 1764 detected for tactic -8654297089785671176.
[WARNING] Skipping tactic 4 due to oom error on requested size of 1764 detected for tactic -7140760933967189247.
[WARNING] Skipping tactic 5 due to oom error on requested size of 1764 detected for tactic -4097850214384059472.
[WARNING] Skipping tactic 6 due to oom error on requested size of 1764 detected for tactic -3689982367035295496.
[WARNING] Skipping tactic 7 due to oom error on requested size of 1764 detected for tactic -2534402059426524406.
[WARNING] Skipping tactic 8 due to oom error on requested size of 1764 detected for tactic -2027588946874785071.
[ERROR] Tactic Device request: 2729MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 1 due to oom error on requested size of 2729 detected for tactic 1.
[ERROR] Tactic Device request: 2728MB Available: 1536MB. Device memory is insufficient to use tactic.
[WARNING] Skipping tactic 2 due to oom error on requested size of 2728 detected for tactic 2.
[WARNING] Skipping tactic 3 due to oom error on requested size of 1764 detected for tactic 56.
[WARNING] Skipping tactic 4 due to oom error on requested size of 2728 detected for tactic 58.
[WARNING] Skipping tactic 0 due to oom error on requested size of 1764 detected for tactic 2105695814191699972.
[WARNING] Skipping tactic 1 due to oom error on requested size of 1764 detected for tactic 2689212690707793357.
[WARNING] Skipping tactic 2 due to oom error on requested size of 1764 detected for tactic 2798075085844016892.
[WARNING] Skipping tactic 3 due to oom error on requested size of 1764 detected for tactic 3091156937974993800.
[WARNING] Skipping tactic 4 due to oom error on requested size of 1764 detected for tactic 3754069740140581927.
[WARNING] Skipping tactic 5 due to oom error on requested size of 1764 detected for tactic 3932578551652369355.
[WARNING] Skipping tactic 6 due to oom error on requested size of 1764 detected for tactic 5483093640784800285.
[WARNING] Skipping tactic 7 due to oom error on requested size of 1764 detected for tactic 5666160310350604399.
[WARNING] Skipping tactic 8 due to oom error on requested size of 1764 detected for tactic 5900614001783877430.
[WARNING] Skipping tactic 9 due to oom error on requested size of 1764 detected for tactic 5925270497649423688.
[WARNING] Skipping tactic 10 due to oom error on requested size of 1764 detected for tactic 5999406432703271895.
[WARNING] Skipping tactic 11 due to oom error on requested size of 1764 detected for tactic 6680916730816870145.
[WARNING] Skipping tactic 12 due to oom error on requested size of 1764 detected for tactic 7158029511300006471.
[WARNING] Skipping tactic 13 due to oom error on requested size of 1764 detected for tactic 7859952145590271433.
[WARNING] Skipping tactic 14 due to oom error on requested size of 1764 detected for tactic 8283847742354150423.
[WARNING] Skipping tactic 15 due to oom error on requested size of 1764 detected for tactic 8642279798680442080.
[WARNING] Skipping tactic 16 due to oom error on requested size of 1764 detected for tactic 9108067304506990859.
[WARNING] Skipping tactic 17 due to oom error on requested size of 1764 detected for tactic -9104099172933216230.
[WARNING] Skipping tactic 18 due to oom error on requested size of 1764 detected for tactic -8956720569082607796.
[WARNING] Skipping tactic 19 due to oom error on requested size of 1764 detected for tactic -8952042869709043207.
[WARNING] Skipping tactic 20 due to oom error on requested size of 1764 detected for tactic -8898856569474934280.
[WARNING] Skipping tactic 21 due to oom error on requested size of 1764 detected for tactic -8774805574135441656.
[WARNING] Skipping tactic 22 due to oom error on requested size of 1764 detected for tactic -8520017388966620486.
[WARNING] Skipping tactic 23 due to oom error on requested size of 1764 detected for tactic -8487084252145372186.
[WARNING] Skipping tactic 24 due to oom error on requested size of 1764 detected for tactic -8391760416076885205.
[WARNING] Skipping tactic 25 due to oom error on requested size of 1764 detected for tactic -7990268040387498660.
[WARNING] Skipping tactic 26 due to oom error on requested size of 1764 detected for tactic -7849113095413980300.
[WARNING] Skipping tactic 27 due to oom error on requested size of 1764 detected for tactic -5590418898350402100.
[WARNING] Skipping tactic 28 due to oom error on requested size of 1764 detected for tactic -5389631537202601150.
[WARNING] Skipping tactic 29 due to oom error on requested size of 1764 detected for tactic -4534876761957424274.
[WARNING] Skipping tactic 30 due to oom error on requested size of 1764 detected for tactic -3237051169894153788.
[WARNING] Skipping tactic 31 due to oom error on requested size of 1764 detected for tactic -2676138141351394855.
[WARNING] Skipping tactic 32 due to oom error on requested size of 1764 detected for tactic -2422160065350346448.
[WARNING] Skipping tactic 33 due to oom error on requested size of 1764 detected for tactic -2125188058121029448.
[WARNING] Skipping tactic 34 due to oom error on requested size of 1764 detected for tactic -2123887091022542343.
[WARNING] Skipping tactic 35 due to oom error on requested size of 1764 detected for tactic -539379305772590030.
[INFO] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 1810, GPU 6113 (MiB)
[ERROR] 10: [optimizer.cpp::computeCosts::1855] Error Code 10: Internal Error (Could not find any implementation for node block_1a_conv_3/Conv2D + add/add + block_1a_relu/Relu.)
[ERROR] Unable to create engine
You can run “./tao-converter -h” for help.
If meet with out-of-memory issue, please decrease the batch size(-m) accordingly.
Or increase the workspace size.
