Hello everyone,
I want convert my MATLAB codes to CUDA MATLAB, can someone tell how can I do that ?
this is a code below in MATLAB as a series, so to use same algorithm but in parallel how can i do that in CUDA MATLAB ?
clc;
clear all;
close all;
tic
img=imread(‘cat.bmp’);
[M N]=size(img);
data1=zeros(M,N);
for i=1:M;
for j=1:N
if img(i,j)>150
data1(i,j)=1;
end
end
end
data=data1;
[x,y] = size(data);
% expand dataset to avoid crash when searching:
data = [zeros(1,y+2);[zeros(x,1) data zeros(x,1)]];
[x,y] = size(data);
labels = zeros(size(data));
nextlabel = 1;
linked = ;
for i = 2:x % for each row
for j = 2:y-1 % for each column
if data(i,j) ~= 0 % not background
% find binary value of neighbours
neighboursearch = [data(i-1,j-1), data(i-1,j), data(i-1,j+1),data(i,j-1)];
% for 4-connectivity, replace with:
% neighboursearch = [data(i-1,j),data(i,j-1)];
% search for neighbours with binary value 1
[~,n,neighbours] = find(neighboursearch==1);
% if no neighbour is allready labeled: assign new label
if isempty(neighbours)
linked{nextlabel} = nextlabel; %#ok<*AGROW>
labels(i,j) = nextlabel;
nextlabel = nextlabel+1;
% if neighbours is labeled: pick the lowest label and store the
% connected labels in "linked"
else
neighboursearch_label = [labels(i-1,j-1), labels(i-1,j), labels(i-1,j+1),labels(i,j-1)];
L = neighboursearch_label(n);
labels(i,j) = min(L);
for k = 1:length(L)
label = L(k);
linked{label} = unique([linked{label} L]);
end
end
end
end
end
% remove the previous expansion of the image
labels = labels(2:end,2:end-1);
%% join linked areas
% for each link, look through the other links and look for common labels.
% if common labels exist they are linked → replace both link with the
% union of the two. Repeat until there is no change in the links.
change2 = 1;
while change2 == 1
change = 0;
for i = 1:length(linked)
for j = 1:length(linked)
if i ~= j
if sum(ismember(linked{i},linked{j}))>0 && sum(ismember(linked{i},linked{j})) ~= length(linked{i})
change = 1;
linked{i} = union(linked{i},linked{j});
linked{j} = linked{i};
end
end
end
end
if change == 0
change2 = 0;
end
end
% removing redundat links
linked = unique(cellfun(@num2str,linked,‘UniformOutput’,false));
linked = cellfun(@str2num,linked,‘UniformOutput’,false);
K = length(linked);
templabels = labels;
labels = zeros(size(labels));
% label linked labels with a single label:
for k = 1:K
for l = 1:length(linked{k})
labels(templabels == linked{k}(l)) = k;
end
end
toc
