Hi, I know there are similar topics to this problem, but the errormessage that I get is different to others.
My System:
Vista 32bit
Cuda 2.0
MS Visual Professional 2005
Matlab 2007b
Cuda Driver is called “NVIDIADisplayWinVista(178_08)Int.exe”
I have a 8800 GTX
This says the manual:
---- Compile and test the CUFFT interface ----
dir
. FS_vortex.m bin nvmex.m
… README.txt fft2_cuda.c nvmex_helper.m
FS_2Dflow.pdf Szeta.cu fft2_cuda_sp_dp.c nvmexopts.bat
FS_2Dturb.m Szeta.m ifft2_cuda.c speed_fft.m
mex fft2_cuda.c -IC:\CUDA\include -LC:\CUDA\lib -lcudart -lcufft
mex fft2_cuda_sp_dp.c -IC:\CUDA\include -LC:\CUDA\lib -lcudart -lcufft
mex ifft2_cuda.c -IC:\CUDA\include -LC:\CUDA\lib -lcudart -lcufft
dir
. README.txt fft2_cuda.mexw32 nvmex.m
… Szeta.cu fft2_cuda_sp_dp.c nvmex_helper.m
FS_2Dflow.pdf Szeta.m fft2_cuda_sp_dp.mexw32 nvmexopts.bat
FS_2Dturb.m bin ifft2_cuda.c speed_fft.m
FS_vortex.m fft2_cuda.c ifft2_cuda.mexw32
speed_fft
I have all these files installed and it is in the path-folder. Then I try the first command:
Then I get this:
Writing library for fft2_cuda.mexw32
c:\users\alexan~1\appdata\local\temp\mex_c5af1e81-c117-4f32-9e80-fe0c7093dcf5\fft2_cuda.obj .text: undefined reference to ‘_cudaMalloc@8’
c:\users\alexan~1\appdata\local\temp\mex_c5af1e81-c117-4f32-9e80-fe0c7093dcf5\fft2_cuda.obj .text: undefined reference to ‘_cudaMemcpy@16’
c:\users\alexan~1\appdata\local\temp\mex_c5af1e81-c117-4f32-9e80-fe0c7093dcf5\fft2_cuda.obj .text: undefined reference to ‘_cufftPlan2d@16’
c:\users\alexan~1\appdata\local\temp\mex_c5af1e81-c117-4f32-9e80-fe0c7093dcf5\fft2_cuda.obj .text: undefined reference to ‘_cufftExecC2C@16’
c:\users\alexan~1\appdata\local\temp\mex_c5af1e81-c117-4f32-9e80-fe0c7093dcf5\fft2_cuda.obj .text: undefined reference to ‘_cufftDestroy@4’
c:\users\alexan~1\appdata\local\temp\mex_c5af1e81-c117-4f32-9e80-fe0c7093dcf5\fft2_cuda.obj .text: undefined reference to ‘_cudaFree@4’
E:\PROGRA~2\MATLAB\R2007A\BIN\MEX.PL: Error: Link of ‘fft2_cuda.mexw32’ failed.
??? Error using ==> mex at 206
Unable to complete successfully.
For the other both compiler-commands
I get similar messages. When I start
speed_fft
Matlab brakes down. It closes without message.
The only idea that I still have is to install XP 32bit. But does that really help?
Hm, I really need to get that running, I hope someone can help me…
grettings
Alexander
