matlab mex file
Hello.
I am trying to compile the GPUmat toolbox in matlab. I have cuda 9.1 on Ubuntu 16.04 amd64, matlab 2017b and gcc 5.4.0. When I try to compile the library I initially had the following error message:
../../include/GPUtype.hh:165:3: note:   candidate expects 2 arguments, 4
provided
For the following command:
'mex -DMATLAB -DUNIX -outdir . ./GPUtypeDelete.cpp   -I"../../../include"
-I"../../cuda/latest/cudalib" -I"/usr/local/cuda-9.1/include" -I"."
-L"../../lib" -L"../../cuda/latest/cudalib" -L"/usr/local/cuda-9.1/lib64"
-lcublas -lcuda -lcudart  -lgputype -lcudalib  -lcufft'
I added the tag “-DMX_COMPAT_32” (for 32 bits compatibility) to the command line and that seemed to fix the problem. Then I had a series of about 50 errors about undefined references similar to this:
GPUnumeric.cpp:(.text+0x1b16): undefined reference to `cufftDestroy'
I changed the order of the library tags (-lcufft …) and matlab was able to compile some libraries. But I am still having errors about undefined references such as:
../../lib/libgputype.a(GPUmanager.o): In function
`GPUmanager::initStreams()':
GPUmanager.cpp:(.text+0x4ce): undefined reference to `cudaStreamCreate'
`GPUmanager::registerUserModule(char*, char*)':
GPUmanager.cpp:(.text+0x10ac): undefined reference to `cuModuleLoadData'
`GPUmanager::deleteUserModule(char*)':
GPUmanager.cpp:(.text+0x13d4): undefined reference to `cuModuleUnload'
`GPUmanager::registerUserFunction(char*, char*)':
GPUmanager.cpp:(.text+0x164a): undefined reference to `cuModuleGetFunction'
../../lib/libgputype.a(GPUmanager.o): In function `GPUmanager::cleanup()':
GPUmanager.cpp:(.text+0x212d): undefined reference to `cudaStreamDestroy'
../../lib/libgputype.a(GPUop.o): In function `GPUopAllocVector(GPUtype&)':
GPUop.cpp:(.text+0x185b): undefined reference to `cuMemGetInfo_v2'
GPUop.cpp:(.text+0x18c3): undefined reference to `cuMemGetInfo_v2'
GPUop.cpp:(.text+0x198d): undefined reference to `cudaMalloc'
GPUop.cpp:(.text+0x19ac): undefined reference to `cudaMalloc'
../../lib/libgputype.a(GPUnumeric.o): In function
`GPUsetKernelTextureB(GPUtype&, CUfunc_st**, int)':
GPUnumeric.cpp:(.text+0xee8): undefined reference to `cuTexRefSetAddress_v2'
GPUnumeric.cpp:(.text+0xf36): undefined reference to `cuParamSetTexRef'
GPUnumeric.cpp:(.text+0xf82): undefined reference to `cuTexRefSetFormat'
../../cuda/latest/cudalib/libcudalib.a(cudalib.o): In function
`mat_REALIMAG':
cudalib.cpp:(.text+0x2586): undefined reference to `cuFuncSetBlockShape'
cudalib.cpp:(.text+0x259b): undefined reference to `cuFuncSetSharedSize'
cudalib.cpp:(.text+0x25b3): undefined reference to `cuParamSeti'
cudalib.cpp:(.text+0x25d1): undefined reference to `cuParamSetv'
cudalib.cpp:(.text+0x25ef): undefined reference to `cuParamSetv'
cudalib.cpp:(.text+0x260d): undefined reference to `cuParamSetv'
cudalib.cpp:(.text+0x2625): undefined reference to `cuParamSeti'
cudalib.cpp:(.text+0x263d): undefined reference to `cuParamSeti'
cudalib.cpp:(.text+0x2659): undefined reference to `cuParamSeti'
cudalib.cpp:(.text+0x266e): undefined reference to `cuParamSetSize'
cudalib.cpp:(.text+0x2687): undefined reference to `cuLaunchGridAsync'
collect2: error: ld returned 1 exit status
Is this still related to the order in which libraries are being called? If yes, what’s the proper order? I’ve tried many different orders and none fixed the problem.
Thanks,
Baptiste
Just wanted to point out that this library is fairly old at this point (last modified 5 years ago, it seems)
MATLAB has native support for many functions currently:
Unless you really need some specific functionality that is present in that add on library that is not present in MATLAB’s (GPU-enabled) PCT and functions, I would advise to go with the former.
Unfortunately I’m using another toolbox which uses GPUmat to convert a matlab gpuArray to an opengl texture.
Do you need 32 bit compatibility? If you’re compiling 32 bit app (if that is still supported? Check the release notes of the CUDA version) then you want to link to the 32 version of the CUDA libraries… probably explains the undefined references.
Ok thanks. Unfortunately it doesn’t look like 32 bits versions of CUDA are still being released.
