I am trying to implement a forward attention algorithm utilizing cuDNN backend API with version 9.1.1. As concluded in this discussion I am unable to use the MHA pattern as it is only supported on Hopper GPUs. I have now changed my strategy to use two graphs (matmul->scale and softmax->matmul) to represent the attention operation.
I am currently implementing the first graph which I believe subscribes to the first graph pattern listed in this section. I have also made all tensors follow the NHWC layout as stated here.
When I run the following implementation though, I get 0 engine configurations returned by the heuristic and warning message: Warning: CUDNN_STATUS_NOT_SUPPORTED; Reason: mha patterns only support 2, 4 or 5 gemms at: number_of_gemms != 2 && number_of_gemms != 4 && number_of_gemms != 5. I am not sure why the graph is being read as an MHA graph and not a MatMul fusion graph.
What should I change to make the graph be a proper MatMul fusion graph? Is it possible to combine a matrix multiplication and pointwise operation in a non-MHA graph.
#include <cudnn.h>
#include <iostream>
#include <vector>
#define CUDNN_CHECK(status) \
if (status != CUDNN_STATUS_SUCCESS) { \
std::cerr << "cuDNN error at " << __FILE__ << ":" << __LINE__ \
<< ": " << cudnnGetErrorString(status) << std::endl; \
char error_message[256]; \
cudnnGetLastErrorString(error_message, sizeof(error_message)); \
std::cerr << "reason: " << error_message; \
std::cerr << std::endl; \
std::exit(EXIT_FAILURE); \
void print_vector(const std::vector<int64_t> &v, std::string name) {
std::cout << name << ": " << v.size() << ": ";
for (int64_t i : v) {
std::cout << i << " ";
std::cout << std::endl;
cudnnBackendDescriptor_t tensor_descriptor(const std::vector<int64_t> &shape,
const std::vector<int64_t> &strides,
int64_t id,
cudnnDataType_t data_type,
int64_t byte_alignment,
bool is_virtual) {
cudnnBackendDescriptor_t desc;
CUDNN_CHECK(
cudnnBackendCreateDescriptor(CUDNN_BACKEND_TENSOR_DESCRIPTOR, &desc));
CUDNN_CHECK(cudnnBackendSetAttribute(desc, CUDNN_ATTR_TENSOR_UNIQUE_ID,
CUDNN_TYPE_INT64, 1, &id));
CUDNN_CHECK(cudnnBackendSetAttribute(desc, CUDNN_ATTR_TENSOR_DATA_TYPE,
CUDNN_TYPE_DATA_TYPE, 1, &data_type));
CUDNN_CHECK(cudnnBackendSetAttribute(desc, CUDNN_ATTR_TENSOR_BYTE_ALIGNMENT,
CUDNN_TYPE_INT64, 1, &byte_alignment));
CUDNN_CHECK(cudnnBackendSetAttribute(desc, CUDNN_ATTR_TENSOR_DIMENSIONS,
CUDNN_TYPE_INT64,
(int64_t)shape.size(), shape.data()));
desc, CUDNN_ATTR_TENSOR_STRIDES, CUDNN_TYPE_INT64,
(int64_t)strides.size(), strides.data()));
CUDNN_CHECK(cudnnBackendSetAttribute(desc, CUDNN_ATTR_TENSOR_IS_VIRTUAL,
CUDNN_TYPE_BOOLEAN, 1, &is_virtual));
CUDNN_CHECK(cudnnBackendFinalize(desc));
return desc;
std::vector<int64_t> nhwc_strides(const std::vector<int64_t> &shape) {
return {shape[1] * shape[2] * shape[3], 1, shape[1] * shape[3], shape[1]};
std::vector<int64_t> nchw_strides(const std::vector<int64_t> &shape) {
return {shape[1] * shape[2] * shape[3], shape[2] * shape[3], shape[3], 1};
int main() {
std::vector<int64_t> shape_query = {1, 4, 10, 64};
std::vector<int64_t> stride_query = nchw_strides(shape_query);
std::vector<int64_t> shape_scaler = {1, 1, 1, 1};
std::vector<int64_t> stride_scaler = nhwc_strides(shape_scaler);
std::vector<int64_t> shape_key = {1, 4, 10, 64};
std::vector<int64_t> stride_key = nchw_strides(shape_key);
std::swap(shape_key[2], shape_key[3]);
std::swap(stride_key[1], stride_key[2]);
std::vector<int64_t> shape_scores = {1, 4, 10, 10};
std::vector<int64_t> stride_scores = nhwc_strides(shape_scores);
cudnnHandle_t handle;
CUDNN_CHECK(cudnnCreate(&handle));
cudnnDataType_t data_type = CUDNN_DATA_FLOAT;
int64_t data_type_byte_alignment = 4;
cudnnBackendDescriptor_t query =
tensor_descriptor(shape_query, stride_query, 'q', data_type,
data_type_byte_alignment, false);
cudnnBackendDescriptor_t key = tensor_descriptor(
shape_key, stride_key, 'k', data_type, data_type_byte_alignment, false);
cudnnBackendDescriptor_t scores =
tensor_descriptor(shape_scores, stride_scores, 'o', data_type,
data_type_byte_alignment, true);
cudnnBackendDescriptor_t scaler =
tensor_descriptor(shape_scaler, stride_scaler, 'r', data_type,
cudnnBackendDescriptor_t scaled =
tensor_descriptor(shape_scores, stride_scores, 's', data_type,
cudnnBackendDescriptor_t matmul_desc;
CUDNN_CHECK(cudnnBackendCreateDescriptor(CUDNN_BACKEND_MATMUL_DESCRIPTOR,
&matmul_desc));
CUDNN_CHECK(cudnnBackendSetAttribute(matmul_desc,
CUDNN_ATTR_MATMUL_COMP_TYPE,
CUDNN_CHECK(cudnnBackendFinalize(matmul_desc));
cudnnBackendDescriptor_t op_matmul;
CUDNN_BACKEND_OPERATION_MATMUL_DESCRIPTOR, &op_matmul));
op_matmul, CUDNN_ATTR_OPERATION_MATMUL_DESC,
CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &matmul_desc));
CUDNN_CHECK(
cudnnBackendSetAttribute(op_matmul, CUDNN_ATTR_OPERATION_MATMUL_ADESC,
CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &query));
CUDNN_CHECK(
cudnnBackendSetAttribute(op_matmul, CUDNN_ATTR_OPERATION_MATMUL_BDESC,
CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &key));
CUDNN_CHECK(
cudnnBackendSetAttribute(op_matmul, CUDNN_ATTR_OPERATION_MATMUL_CDESC,
CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &scores));
CUDNN_CHECK(cudnnBackendFinalize(op_matmul));
cudnnBackendDescriptor_t pw_mul;
CUDNN_CHECK(cudnnBackendCreateDescriptor(CUDNN_BACKEND_POINTWISE_DESCRIPTOR,
&pw_mul));
cudnnPointwiseMode_t mul_mode = CUDNN_POINTWISE_MUL;
CUDNN_CHECK(cudnnBackendSetAttribute(pw_mul, CUDNN_ATTR_POINTWISE_MODE,
CUDNN_TYPE_POINTWISE_MODE, 1,
&mul_mode));
CUDNN_CHECK(cudnnBackendSetAttribute(pw_mul, CUDNN_ATTR_POINTWISE_MATH_PREC,
CUDNN_CHECK(cudnnBackendFinalize(pw_mul));
cudnnBackendDescriptor_t op_scale;
CUDNN_BACKEND_OPERATION_POINTWISE_DESCRIPTOR, &op_scale));
op_scale, CUDNN_ATTR_OPERATION_POINTWISE_PW_DESCRIPTOR,
CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &pw_mul));
CUDNN_CHECK(
cudnnBackendSetAttribute(op_scale, CUDNN_ATTR_OPERATION_POINTWISE_XDESC,
CUDNN_CHECK(
cudnnBackendSetAttribute(op_scale, CUDNN_ATTR_OPERATION_POINTWISE_BDESC,
CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &scaler));
CUDNN_CHECK(
cudnnBackendSetAttribute(op_scale, CUDNN_ATTR_OPERATION_POINTWISE_YDESC,
CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &scaled));
CUDNN_CHECK(cudnnBackendFinalize(op_scale));
cudnnBackendDescriptor_t op_graph;
cudnnBackendDescriptor_t ops[] = {op_matmul, op_scale};
CUDNN_BACKEND_OPERATIONGRAPH_DESCRIPTOR, &op_graph));
op_graph, CUDNN_ATTR_OPERATIONGRAPH_OPS, CUDNN_TYPE_BACKEND_DESCRIPTOR,
sizeof(ops) / sizeof(ops[0]), ops));
CUDNN_CHECK(cudnnBackendSetAttribute(op_graph,
CUDNN_ATTR_OPERATIONGRAPH_HANDLE,
CUDNN_TYPE_HANDLE, 1, &handle));
CUDNN_CHECK(cudnnBackendFinalize(op_graph));
cudnnBackendDescriptor_t heur_desc;
CUDNN_BACKEND_ENGINEHEUR_DESCRIPTOR, &heur_desc));
heur_desc, CUDNN_ATTR_ENGINEHEUR_OPERATION_GRAPH,
CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &op_graph));
cudnnBackendHeurMode_t heur_mode = CUDNN_HEUR_MODE_A;
CUDNN_CHECK(cudnnBackendSetAttribute(heur_desc, CUDNN_ATTR_ENGINEHEUR_MODE,
CUDNN_TYPE_HEUR_MODE, 1, &heur_mode));
CUDNN_CHECK(cudnnBackendFinalize(heur_desc));
int64_t count = 0;
CUDNN_CHECK(cudnnBackendGetAttribute(
heur_desc, CUDNN_ATTR_ENGINEHEUR_RESULTS, CUDNN_TYPE_BACKEND_DESCRIPTOR,
0, &count, NULL));
std::cout << "engines: " << count << "\n";
std::vector<cudnnBackendDescriptor_t> eng_cfgs(count);
for (cudnnBackendDescriptor_t &cfg : eng_cfgs) {
CUDNN_BACKEND_ENGINECFG_DESCRIPTOR, &cfg));
count, nullptr, eng_cfgs.data()));
cudnnBackendDescriptor_t exec_plan;
CUDNN_BACKEND_EXECUTION_PLAN_DESCRIPTOR, &exec_plan));
exec_plan, CUDNN_ATTR_EXECUTION_PLAN_ENGINE_CONFIG,
CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &cfg));
CUDNN_CHECK(cudnnBackendSetAttribute(exec_plan,
CUDNN_ATTR_EXECUTION_PLAN_HANDLE,
cudnnStatus_t status = cudnnBackendFinalize(exec_plan);
std::cout << cudnnGetErrorString(status) << "\n";
if (status == CUDNN_STATUS_SUCCESS) {
std::cout << "success\n";
} else {
std::cout << "reason: " << error_message << std::endl;
// To be filled in
return 0;
