Max Parallel RTSP streams supported by Jetson Nano
How many parallel RTSP streams are supported by Jetson for real-time object detection without any lags/delays ? Consider each RTSP stream rate is 20 FPS
E.g. Can it support 8 Parallel IP camera’s(5 Mega Pixel) RTSP streams ?
Regards,
Eswar
Please refer to module data sheet:
https://developer.nvidia.com/embedded/dlc/jetson-nano-system-module-datasheet
For decoding single H264 stream, it can be 1080p 240fps. If your source is 1080 30fps. It should achieve 8x 1080p30.
