Hi there
Does anyone know of any MDL implementations (ie declarative material definition) of USDPreviewSurface and/or Autodesk StandardSurface?
Thanks very much
Brian
What MDL version do you need?
There is the MaterialX MDL backend (https://github.com/materialx/MaterialX/tree/v1.38) which supports StandardSurface through MaterialX. But i also have a monolithic implementation here, still misses sheen which will make it require MDL 1.6. I could clean this up and post here.
Also soon to come omniverse beta will have a usdpreview implementation.
I’m working off the latest in GitHub, so… MDL 1.6 is fine.
That would be cool, thanks!
But no rush, in your own time.
Great, I’ll keep an eye out for that.
Thanks Jan!
Here is my implementation of ad_standard_surface. I already added sheen. This is not an official release but code to use at your own risk. Of course there are some limitations. :
-sheen only over diffuse, not over sss (will need upcomming MDL 1.7)
-slightly different for edgecolor since in use our complex_ior implementation
-thin film gives different results for so far unknown reasons
-additional transmission roughness not implemented because i did not find documentation or implementation in the osl reference
ad_standard_surface.zip (6.1 KB)
Hi Jan
Now that 1.7 is out, do you have an updated version of the ADStandardSurface?
thanks very much
Brian
not yet, but i will work on it asap.
Awesome, thanks Jan
And no rush, in your own time :)
cheers!
