Board: Nvidia Jetson Xavier NX
L4T version: 32.5.1
I would like to measure the bitrate of the transfer between ram and the hardware DMA buffer.
If I understand correctly, the following pipeline :
nvarguscamerasrc ! 'video/x-raw(memory:NVMM),format=NV12' ! nvvidconv ! 'video/x-raw,format=NV12' ! fakesink
Will copy the data from the DMA buffer to RAM, please confirm that it is correct.
We are encountering some difficulties with a GStreamer pipeline and we believe that we might reach the limit bandwidth of the DMA Buf - RAM transfer.
I would like to measure this transfer, from RAM to DMA buffer and other way around.
How to do that ?
DaneLLL
3
Yes, the frame data is copied from DMA buffer(NVMM buffer) to CPU buffer. For further information, you can download the source code and check:
L4T R32.5.1 Release Page | NVIDIA Developer
L4T Driver Package (BSP) Sources
Hey ! @DaneLLL thanks for your answer .
I am only trying to measure the data rate between DMA buf and RAM. How to do that ?
DaneLLL
5
You may check which function call yo would like to profile. And add
gettimeofday(2) - Linux manual page
before and after the function call. To get how much time is used in the function.
@DaneLLL thanks for your answer.
I didnt write any code, I am simply using available elements, e.g.
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM),format=NV12' ! \
nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' !
fakesink
To do the following copies: DMA Buf → CPU Buf → DMA Buf
I want to measure those transfers and figure out the upper limit, hopefully with some lower level measurement ?
DaneLLL
7
There is no existing code for the profiling, so you would need to add it to source code of nvvidconv plugin and rebuild it.
Is there any debug tool that would allow me to get the value for the whole board ? Maybe some kernel debug endpoints or something ?
DaneLLL
9
For profiling the plugin, you would need to add debug prints manually. For profiling overall system status, you can run sudo tegrastats.
Tegrastats gives the following output, but the data rate between DMA buf and CPU buff is not in it :
RAM 830/7774MB (lfb 1547x4MB) SWAP 0/3887MB (cached 0MB) CPU [36%@1420,30%@1420,35%@1420,34%@1420,52%@1420,44%@1420] EMC_FREQ 3%@1600 GR3D_FREQ 0%@114 VIC_FREQ 0%@115 APE 150 MTS fg 1% bg 13% AO@58.5C GPU@59C PMIC@100C AUX@57.5C CPU@61.5C thermal@59C VDD_IN 4592/4592 VDD_CPU_GPU_CV 1797/1797 VDD_SOC 1277/1277
DaneLLL
11
The loading on the CPU cores indicates the memory copy.
system
Closed
13
