HW : Jetson NX devkit
purpose : run object detection example code with remote camera (need to use openCV)
here is my code modified from example code.
import cv2
import jetson.inference
import jetson.utils
import numpy as np
#camera = cv2.VideoCapture(‘http://10.42.0.80:8090’) #remote cam url
camera = cv2.VideoCapture(0)
net = jetson.inference.detectNet(“ssd-mobilenet-v2”, threshold=0.5)
_,img = camera.read()
width = np.shape(img)[1]
height = np.shape(img)[0]
print("\n debug 1\n")
input_img = jetson.utils.cudaFromNumpy(img)
print("\n debug 2\n")
detections = net.Detect(input_img,width,height)
print("detections : ",detections)
In my opinion,
The problem seem to be in this line.
The error below occurs.
Cuda Error in allocateContextResources: 700 (an illegal memory access was encountered)
If the “jetson.utils.cudaFromNumpy” command is run correctly,
python script need to show the following result
I think an error occurred because the cuda memory could not
be free due to an unknown problem.
How can I solve this problem?
Full error code of above code
debug 1
jetson.utils – cudaFromNumpy() ndarray dim 0 = 480
jetson.utils – cudaFromNumpy() ndarray dim 1 = 640
jetson.utils – cudaFromNumpy() ndarray dim 2 = 3
debug 2
[TRT] …/rtSafe/cuda/caskConvolutionRunner.cpp (317) - Cuda Error in allocateContextResources: 700 (an illegal memory access was encountered)
[TRT] FAILED_EXECUTION: std::exception
[TRT] detectNet::Detect() – failed to execute TensorRT context
File “test3.py”, line 16, in
Exception: jetson.inference – detectNet.Detect() encountered an error classifying the image
PyTensorNet_Dealloc()
[cuda] cudaFreeHost(mDetectionSets[0])
[cuda] an illegal memory access was encountered (error 700) (hex 0x2BC)
[cuda] /home/user/jetson-inference/c/detectNet.cpp:66
[cuda] cudaFreeHost(mClassColors[0])
[cuda] /home/user/jetson-inference/c/detectNet.cpp:74
gridAnchorPlugin.cpp, 162, 700
gridAnchorPlugin.cpp, 163, 700
gridAnchorPlugin.cpp, 166, 700
gridAnchorPlugin.cpp, 167, 700
gridAnchorPlugin.cpp, 168, 700
[TRT] …/rtExt/cuda/cudaFusedConvActRunner.cpp (90) - Cuda Error in destroyFilterTexture: 700 (an illegal memory access was encountered)
[TRT] INTERNAL_ERROR: std::exception
[TRT] …/rtSafe/safeRuntime.cpp (32) - Cuda Error in free: 700 (an illegal memory access was encountered)
terminate called after throwing an instance of ‘nvinfer1::CudaError’
what(): std::exception
Aborted (core dumped)
