If the data is defined on the main(Host) program, is it required to copy the data from host to device? If its required to copy, then is memory allocation on GPU a must?
Example: I've an array with 10 (i.e. a[10]) elements initialized to 1,2,3 .. 10( a[0]..a[9]) on the host code.
The kernel call is:
addarr<<<N,1>>> (a);
As we are passing the base address of the array "a", is it still required to allocate memory on gpu and copy the contents?
Thanks in advance
