memory fragmentation (perhaps?)
edit: my /previous/ issue, not my current one was memory corruption. I actually think I got rid of that…that was a different error message entirely. Something along the lines of glibc detected such-and-such* !prev, and then a map of allocated addresses and a stacktrace. Sorry about the confusing title.
I am researching quantum chemistry and plasma physics using a robust, perturbative, renormalized QFT formulated using MaxEnt, Spacetime Algebra/Bivector General Relativity, and active stochastic processes (see e.g. doi:10.1016/j.physletb.2004.03.036, doi:10.1016/j.physletb.2007.10.060, also check out publications by D. Hestenes and E.T. Jaynes). The result will be open-sourced as soon as I can debug it, so feel free to ask for code snippets, etc.
Right now, I’ve got a nasty problem. Using the runtime API, I need to allocate 2 float arrays, each 1286464, asynchronously on a 512mb version of the 8600GT (yes, I know, I’m cheap). Then I need to call my initialization kernel on an input file stored as a uchar*, which has only about 26 registers—I launch 2 streams, each 2 blocks of size (2,2,2). These sizes are subject to as much change as they need given the hardware. I do, however, want to test support for asynchronous transfers and launches if I can, because I made an object-oriented wrapper and am going to write template to abstract the initialization kernel (right now it’s just a dummy that acts as “cudaMemset”). Ideally, more powerful hardware would allow applications to perform multiple simulations without interference.
I don’t know exactly what needs to be fixed. Here is what seems to be the problem code, lines 36-76:
__host__ cystGPUMsim::cystGPUMsim(struct simParams *params, const char* buff){
			dp=(cudaPitchedPtr*) malloc(sizeof(cudaPitchedPtr)*(nstreams));
			width=params->width;
			height=params->height;
			depth=params->depth;
			dT=params->dT;
			dx=params->dx;
			n=params->n;
			grid=params->grid;
			block=params->block;
			max=params->max;
			nstreams=params->nstreams;
			ca_extent.width  = width/nstreams;
			ca_extent.height = height;
			ca_extent.depth  = depth;
			unsigned char* dbuff;
			cudaMalloc((void**) &dbuff, sizeof(buff));
			cudaMemcpy(dbuff, buff, sizeof(buff), cudaMemcpyHostToDevice);
			stream=(cudaStream_t*) malloc(sizeof(cudaStream_t)*nstreams);
			for (int s = 0; s < nstreams; ++s){
				dp[s]=make_cudaPitchedPtr( NULL, width/nstreams*sizeof(float), height, depth*4 );
				cudaMalloc3D(&(dp[s]), ca_extent);
				for(int i=0; i<int(width/nstreams); i+=grid.x*block.x){
					for(int j=0; j<int(height); i+=grid.y*block.y){
						for(int k=0; k<int(depth*4); i+=grid.z*block.z){
							initialize<<<grid, block, 0, stream[s]>>>((float***) dp[s].ptr, dbuff, i,j,k);
							cudaThreadSynchronize();
							checkCUDAError(" ");
			cudaFree(dbuff);
Compile-time yields no relevant warnings. What I see on runtime is the following error:
and the gdb stack says:
I would use deviceemu to debug. But right now, if I compile it with device emulation, I receive the following warnings:
Then, when I run it, this odd segmentation fault occurs:
I think this has something to do with my host system’s being single-threaded; I am pretty sure the CUDA Programming Guide said you need at least enough threads on the host to run the device code.
I am running Ubuntu 8.04 32-bit Desktop Ed. with the Cuda 2.1 Beta Toolkit and SDK (my installation doesn’t seem to cause any problems), drivers 180.06 beta, and all of the most recent package updates (=> up-to-date GCC, etc.). I have a Pentium D 805, 1GB of RAM (DDR2, don’t know what speed), and a BFG Tech GeForce 8600 GT OC w/ 512 GB GDDR3 (quite a mouthful). Only nvcc settings are -G, -g, and -arch SM_11, which is the correct target (I checked. I had an atomicAdd that I got rid of, if you must know).
Any thoughts? Appreciate your comments.
Can you post full source?
sure, sure. here goes:
cyst.h:
/*   Copyright (c) 2009 Kevin Daley
	The following code is part of cYst.
	cYst is free software: you can redistribute it and/or modify
	it under the terms of the GNU General Public License as published by
	the Free Software Foundation, either version 3 of the License, or
	(at your option) any later version.
	cYst is distributed in the hope that it will be useful,
	but WITHOUT ANY WARRANTY; without even the implied warranty of
	MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
	GNU General Public License for more details.
	You should have received a copy of the GNU General Public License
	along with cYst.  If not, see <http://www.gnu.org/licenses/>.
#include <cuda_gl_interop.h>
#include <cstdio>
#include <cstdlib>
#include <cmath>
 __global__ void initialize(float*** hd, unsigned char* file, int i, int j, int k);
extern int resx, resy;
namespace cyst{
struct simParams{
	float dT;
	float n;
	float4 dx;
	dim3 grid;
	dim3 block;
	float max;
	unsigned int width, height, depth;
	int nstreams;
class cystGPUMsim{
protected:
	cudaPitchedPtr *dp;
	float dT;
	float4 dx;
	float n;
	dim3 grid;
	dim3 block;
	cudaStream_t *stream;
	int nstreams;
	float max;
	cudaExtent ca_extent;
public:
	__host__ explicit cystGPUMsim(struct simParams *params, const char* buff);
	__host__ virtual ~cystGPUMsim();
	__host__ void callGPUsim(int frames);
	__host__ float* retrieveGPUsim();
cyst.cu
#include "cyst.cu"
__global__ void initialize(float*** hd, unsigned char* file, int i, int j, int k){
	uint3 pg=make_uint3(threadIdx.x+blockIdx.x*blockDim.x+i,threadIdx.x+blockIdx
.y*blockDim.y+j,threadIdx.z+blockIdx.z*blockDim.z+k);
	hd[pg.x][pg.y][pg.z]=3;
void demo(){
cudaSetDevice(0);
struct simParams *parms= new simParams;
parms->dT=10;
parms->n=.5;
parms->dx=make_float4(0.1,0.1,0.1,0.1);
dim3 grid (2,1);
dim3 block (2,2,2);
parms->width=128;
parms->height=128;
parms->depth=64;
parms->max=50.0f;
parms->nstreams=2;
cudaSetDevice(0);
	parms->grid=grid;
	parms->block=block;
	cyst::cystGPUMsim* sim=new cyst::cystGPUMsim(parms, "k");
	sim->callGPUsim(1);
	float* H=sim->retrieveGPUsim();
	delete sim;
	FILE* f=fopen("out.dat","rw+");
	for(int i=0; i<256; i++){
		for(int j=0; j<256; j++){
			for(int k=0; k<256; k++){
				fprintf(f, "%f %f %f %f %f %f %f %f\n",
i*parms->dx.x, j*parms->dx.y,k*parms->dx.z, k*parms->dx.w,
H[(i+j*256+k*256*1024)+3], H[(i+j*256+k*256*1024)],
H[(i+j*256+k*256*1024)+1],
H[(i+j*256+k*256*1024)+2]);
	fclose(f);
	exit(0);
and demo.cu
#include "cyst.cu"
void demo(){
cudaSetDevice(0);
parms->dT=10;
parms->n=.5;
dim3 grid (2,1);
dim3 block (2,2,2);
parms->width=128;
parms->height=128;
parms->depth=64;
parms->max=50.0f;
parms->nstreams=2;
cudaSetDevice(0);
	parms->grid=grid;
	parms->block=block;
	sim->callGPUsim(1);
	delete sim;
	fclose(f);
	exit(0);
and kernel.cu:
//planck units
#define const_pi 3.1415927f
#define kC 1.0f
#define kB 1.0f
#define lightspeed  1.0f
#define finestructure 1.0f
#include <sm_11_atomic_functions.h>
__global__ void kernelGPU(float ***H, float dT, float4 dx, float n, float max, int i, int j, int k){
		float mg=0;
		uint3 pl=make_uint3(threadIdx.x, threadIdx.y, threadIdx.z);
		float x=0.0f, y=0.0f, z=0.0f;
		__shared__ float shared[2][2][2],  E[2][2][2], E2[2][2][2];
		E[pl.x][pl.y][pl.z]=H[pg.x][pg.y][pg.z];
		E2[pl.x][pl.y][pl.z]=0.0f;
		for(float i=0; i<max && i<E[pl.x][pl.y][pl.z]; i+=n){
						if((threadIdx.z+1)%4==0){
							shared[pl.x][pl.y][pl.z]=i;
							mg=sqrtf(pow(shared[pl.x][pl.y][pl.z-3],2.0f)+pow(shared[pl.x][pl.y][pl.z-2],2.0f)+pow(shared[pl.x][pl.y][pl.z-1],2.0f));
							x+=shared[pl.x][pl.y][pl.z]*(cosf(mg)-1/mg*shared[pl.x][pl.y][pl.z]*sinf(mg));
						else if((threadIdx.z+1)%3==0){
							mg=sqrtf(pow(shared[pl.x][pl.y][pl.z+1],2.0f)+pow(shared[pl.x][pl.y][pl.z-2],2.0f)+pow(shared[pl.x][pl.y][pl.z-1],2.0f));
						else if((threadIdx.z+1)%2==0){
							mg=sqrtf(pow(shared[pl.x][pl.y][pl.z+1],2.0f)+pow(shared[pl.x][pl.y][pl.z+2],2.0f)+pow(shared[pl.x][pl.y][pl.z-1],2.0f));
						else{
							mg=sqrtf(pow(shared[pl.x][pl.y][pl.z+1],2.0f)+pow(shared[pl.x][pl.y][pl.z+2],2.0f)+pow(shared[pl.x][pl.y][pl.z+3],2.0f));
						shared[pl.x][pl.y][pl.z]=x;
						__syncthreads();
						__syncthreads();
							z=shared[pl.x][pl.y][pl.z-1];
							y=shared[pl.x][pl.y][pl.z-2];
							x=shared[pl.x][pl.y][pl.z-3];
						__syncthreads();
						if((threadIdx.z+1)%4==0 && int(fdividef(x,dx.x))>=0 && int(fdividef(x,dx.x))){
							E2[pl.x+int(fdividef(x,dx.x))][pl.y+int(fdividef(y,dx.y))][pl.z+4*int(fdividef(z,dx.z))]+=shared[pl.x][pl.y][pl.z];
						else if((threadIdx.z+1)%4==0){
							H[int(fdividef(x,dx.x))+pg.x][int(fdividef(y,dx.y))+pg.y][(int(fdividef(z,dx.z))*4+pg.z)]+=i;
						E2[pl.x][pl.y][pl.z]-=i;
						__syncthreads();
			H[pg.x][pg.y][pg.z]=E[pl.x][pl.y][pl.z]+E2[pl.x][pl.y][pl.z];
Finally, main.cpp:
extern void demo();
int main(int argc, char** argv){
	demo();
There you go.
bump
