Hello. When I use a simple example like this:
import os
os.environ['OPENBLAS_CORETYPE'] = 'ARMV8'
import cv2
import sys
import vpi
import numpy as np
import time
from argparse import ArgumentParser
import gc
backend = vpi.Backend.CUDA
print('1')
inVideo = cv2.VideoCapture(1)
inVideo.set(cv2.CAP_PROP_FRAME_WIDTH, 480)
inVideo.set(cv2.CAP_PROP_FRAME_HEIGHT, 640)
inVideo.set(cv2.CAP_PROP_FPS, 30)
if int(cv2.__version__.split('.')[0]) >= 3:
extOutputVideo = '.mp4'
fourcc = cv2.VideoWriter_fourcc(*'avc1')
inSize = (int(inVideo.get(cv2.CAP_PROP_FRAME_WIDTH)), int(inVideo.get(cv2.CAP_PROP_FRAME_HEIGHT)))
fps = inVideo.get(cv2.CAP_PROP_FPS)
else:
# MP4 support with OpenCV-2.4 has issues, we'll use
# avi/mpeg instead.
extOutputVideo = '.avi'
fourcc = cv2.cv.CV_FOURCC('M','P','E','G')
inSize = (int(inVideo.get(cv2.cv.CV_CAP_PROP_FRAME_WIDTH)), int(inVideo.get(cv2.cv.CV_CAP_PROP_FRAME_HEIGHT)))
fps = inVideo.get(cv2.cv.CV_CAP_PROP_FPS)
print(inSize)
outVideo = cv2.VideoWriter('denoised_python'+str(sys.version_info[0])+'_'+'cuda.avi',
cv2.VideoWriter_fourcc('X', 'V', 'I', 'D'), fps, inSize)
curFrame = 0
new_frame_time = 0
font = cv2.FONT_HERSHEY_SIMPLEX
prev_frame_time = 0
while True:
curFrame+=1
print("Frame: {}".format(curFrame))
ret, cvFrame = inVideo.read()
print(cvFrame.shape)
if not ret:
break
start_time = time.time()
with vpi.Backend.CUDA:
frame = vpi.asimage(cvFrame).convert(vpi.Format.NV12_ER)
denoised = frame.eqhist()
denoised = denoised.convert(vpi.Format.RGB8)
print("--- %s seconds ---" % (time.time() - start_time))
with denoised.rlock():
frame=denoised.cpu()
new_frame_time = time.time()
fps = 1/(new_frame_time-prev_frame_time)
prev_frame_time = new_frame_time
fps = str(int(fps))
cv2.putText(frame, fps, (7, 70), font, 3, (100, 255, 0), 3, cv2.LINE_AA)
#outVideo.write(frame)
cv2.imshow('Input', frame)
c = cv2.waitKey(1)
if c == 27:
break
I get a memory leak.
I could not find a proper help for the Python API
