memory operation inside kernel simultaneous using of variable inside the kernel function
I have simple code, where I sent to kernel variable which I want to be changed by threads. Each thread is adding 1 to this integer variable. I declared 10 threads, and when execution is finished then inside the variable there is only 1. Like only one thread changed the variable. How to do it properly ?
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include <stdio.h>
__global__ void Kernel(int *c)
    *c += 1;
int main()
	int numberOfThreads = 10;
    int c = 0;
    int *dev_c = 0;
    cudaError_t cudaStatus;
// Choose which GPU to run on, change this on a multi-GPU system.
    cudaStatus = cudaSetDevice(0);
    if (cudaStatus != cudaSuccess) {
        fprintf(stderr, "cudaSetDevice failed!  Do you have a CUDA-capable GPU installed?");
        goto Error;
// Allocate GPU buffers for three vectors (two input, one output)    .
    cudaStatus = cudaMalloc((void**)&dev_c, sizeof(int));
        fprintf(stderr, "cudaMalloc failed!");
        goto Error;
	cudaMemcpy(dev_c, &c, 1, cudaMemcpyHostToDevice);
// Launch a kernel on the GPU with one thread for each element.
    Kernel<<<1, numberOfThreads>>>(dev_c);
// cudaDeviceSynchronize waits for the kernel to finish, and returns
    // any errors encountered during the launch.
    cudaStatus = cudaDeviceSynchronize();
        fprintf(stderr, "cudaDeviceSynchronize returned error code %d after launching addKernel!\n", cudaStatus);
        goto Error;
// Copy output vector from GPU buffer to host memory.
    cudaStatus = cudaMemcpy(&c, dev_c, sizeof(int), cudaMemcpyDeviceToHost);
        fprintf(stderr, "cudaMemcpy failed!");
        goto Error;
Error:
    cudaFree(dev_c);
	// cudaDeviceReset must be called before exiting in order for profiling and
	// tracing tools such as Parallel Nsight and Visual Profiler to show complete traces.
    cudaStatus = cudaDeviceReset();
        fprintf(stderr, "cudaDeviceReset failed!");
        return 1;
	printf("Levensthein: %d\n",c);
	printf("Hit any key to terminate\n");
        getchar();
return 0;
You need to use atomic operations of multiple threads can modify the same variable in parallel:
    atomicAdd(c, 1);
Thank You, but what should I include to have access to this function ? and where can I find more information about these atomic functions ?
I included device_functions.h but it didn’t help.
It seems that in properties of project in visual studio 2010 there has to be option : compute_11,sm_11
In Cuda/C++ → Device → Code Generation
