Memory problems arise when RTX50 series graphics cards are deployed at the same time
Description
I have problems deploying my ONNX model with TensorRT after I trained the model to convert it to ONNX format with Pytorch.
A clear and concise description of the bug or issue.
It is normal to deploy a small number of models at the same time, but when the number of models I deployed at the same time reaches 10 or more, a memory exception will occur during the inference process. The instruction 0x000001FA19A53000 memory is referenced. This memory cannot be read. What I can be sure is that this problem has never occurred on the RTX40 series graphics cards.
Environment
TensorRT Version: 10.9.0.34
GPU Type: RTX 5070
Nvidia Driver Version: GeForce Game Ready 576.52
CUDA Version: CUDA 12.8
CUDNN Version: Cudnn 12x
Operating System + Version: Windows10
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
  • Exact steps/commands to build your repro
  • Exact steps/commands to run your repro
  • Full traceback of errors encountered
To resolve the issue, the user can try the following:
  1. Increase Memory Pool: Increase the memory pool available to TensorRT to avoid the memory exception error.
  2. Optimize Memory Usage: Optimize memory usage by configuring TensorRT to use less memory or by reducing the number of models deployed simultaneously.
  3. Update Drivers and Software: Ensure that the graphics drivers, CUDA, and cuDNN are up-to-date, as newer versions may resolve the issue.
  4. If none of the above works, Please Provide a reproducible example, including models, data files, and scripts, to help diagnose the issue.
    [/quote]
  1. I tried updating my CUDA, CUdnn, TensorRT, and driver, but the issue persists.
  2. I allocated memory for each model after loading to reduce frequent memory allocation and release steps during inference. However, a new problem has arisen. When I run only one model, the inference results are consistent with those output by onnxruntime. However, when I use multithreading to run inference on both models, the inference results are 20% likely to be very strange, while the other 80% are normal. How can I resolve this issue?
Can you pls help with your model and steps to repro?
