• Hardware Platform (Jetson / GPU) RTX 2060 Super.
• DeepStream Version 5.0.1
• TensorRT Version 7.0.0.11
• NVIDIA GPU Driver Version (valid for GPU only) 460
• Issue Type( questions, new requirements, bugs) Question
I am trying to run deepstream_imagedata-multistream.py added to it messagebroker, I modified the pipeline into this:
pipeline.add(pgie)
pipeline.add(tracker)
pipeline.add(tiler)
pipeline.add(nvvidconv)
pipeline.add(filter1)
pipeline.add(nvvidconv1)
pipeline.add(nvosd)
pipeline.add(tee)
pipeline.add(queue1)
pipeline.add(queue2)
pipeline.add(msgconv)
pipeline.add(msgbroker)
pipeline.add(sink)
if is_aarch64():
pipeline.add(transform)
And the linking like this:
streammux.link(pgie)
pgie.link(tracker)
tracker.link(nvvidconv1)
nvvidconv1.link(filter1)
filter1.link(tiler)
tiler.link(nvvidconv)
nvvidconv.link(nvosd)
nvosd.link(tee)
queue1.link(msgconv)
msgconv.link(msgbroker)
if is_aarch64():
queue2.link(transform)
transform.link(sink)
else:
queue2.link(sink)
And added the needed configurations to run using Kafka, I set the consumer to my host, and added the needed functions from deepstream-test4 to be able to send messages.
This is the logic for sending message added in the tiler_sink_pad_buffer_probe function inside the l_obj loop:
if frame_number % 30 == 0:
# Frequency of messages to be send will be based on use case.
# Here message is being sent for first object every 30 frames.
# Allocating an NvDsEventMsgMeta instance and getting reference
# to it. The underlying memory is not manged by Python so that
# downstream plugins can access it. Otherwise the garbage collector
# will free it when this probe exits.
msg_meta = pyds.alloc_nvds_event_msg_meta()
msg_meta.bbox.top = obj_meta.rect_params.top
msg_meta.bbox.left = obj_meta.rect_params.left
msg_meta.bbox.width = obj_meta.rect_params.width
msg_meta.bbox.height = obj_meta.rect_params.height
msg_meta.frameId = frame_number
msg_meta.trackingId = long_to_int(obj_meta.object_id)
# msg_meta.confidence = obj_meta.confidence
msg_meta = generate_event_msg_meta(msg_meta, obj_meta.class_id, stream_id)
user_event_meta = pyds.nvds_acquire_user_meta_from_pool(batch_meta)
if user_event_meta:
user_event_meta.user_meta_data = msg_meta
user_event_meta.base_meta.meta_type = pyds.NvDsMetaType.NVDS_EVENT_MSG_META
# Setting callbacks in the event msg meta. The bindings layer
# will wrap these callables in C functions. Currently only one
# set of callbacks is supported.
pyds.set_user_copyfunc(user_event_meta, meta_copy_func)
pyds.set_user_releasefunc(user_event_meta, meta_free_func)
pyds.nvds_add_user_meta_to_frame(frame_meta, user_event_meta)
else:
print("Error in attaching event meta to buffer\n")
This works on one stream, the question is; How do i make this run on different sources/streams ? , I checked the C++ version for handling multi-streams and message broker but i didn’t manage to find equivalent functions in the python version.
Any help is appreciated,
