We’ve a custom carrier board for the TX. It uses a microSD card slot. We have connected the microSD card exactly as described in the JetsonTX1_TX2_Developer_Kit_Carrier_Board_Specification for the Jetson board.
However the microSD card doesn’t have a C_DETECT Pin. So we tied the SDCARD_CS# pin to ground.
I understand based on https://devtalk.nvidia.com/default/topic/1004742/?comment=5130398 that this will cause us to loose the HotPlug feature. We’re OK with that. We can insert the SDCard before boot and keep it there all the time.
I look at drivers/mmc/host/sdhci-tegra.c in the kernel sources and it seems that if the CD-GPIO is detected to be low, then it’s assumed that the SDCard is present regardless of the interrupt. So it should work.
Currently what we’re seeing is that a freshly flashed (from Jetpack 3.1) Jetson TX1 fails to boot up on this carrier board if a freshly formatted (FAT) SDCard is inserted. If SDCard isn’t inserted it boots up fine. Here is the console error.
[ 5.115463] mmc1 tuning done saved tap delay=169
[ 5.120074] mmc1: hw tuning done ...
[ 5.123645] mmc1: tuning_window[0]: 0xffffffff
[ 5.128081] mmc1: tuning_window[1]: 0xffffc7ff
[ 5.132517] mmc1: tuning_window[2]: 0xffffffff
[ 5.136954] mmc1: tuning_window[3]: 0x3fffffff
[ 5.141389] mmc1: tuning_window[4]: 0xfffffffe
[ 5.145825] mmc1: tuning_window[5]: 0xffffffff
[ 5.150260] mmc1: tuning_window[6]: 0xffe3ffff
[ 5.154695] mmc1: tuning_window[7]: 0x7fffffff
[ 5.159130] sdhci: Tap value: 169 | Trim value: 2
[ 5.163825] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 5.169409] mmc1: new ultra high speed SDR50 SDHC card at address aaaa
[ 5.176221] mmcblk0: mmc1:aaaa SL08G 7.40 GiB
[ 5.196742] mmcblk0: p1
[ 5.201026] [OV5693]: probing v4l2 sensor.
[ 5.205256] ov5693 6-0036: camera_common_regulator_get vana ERR: fffffffffffffdfb
[ 5.212835] ov5693 6-0036: camera_common_regulator_get vif ERR: fffffffffffffdfb
[ 5.254429] mmc0: queuing unknown CIS tuple 0x80 (5 bytes)
[ 5.254509] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 5.254521] VFS: Mounted root (vfat filesystem) on device 179:1.
[ 5.254580] devtmpfs: error mounting -2
[ 5.254909] Freeing unused kernel memory: 1208K (ffffffc001175000 - ffffffc0012a3000)
[ 5.254929] Freeing alternatives memory: 76K (ffffffc0012a3000 - ffffffc0012b6000)
[ 5.255119] Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[ 5.255123] CPU: 3 PID: 1 Comm: swapper/0 Tainted: G W 4.4.38-tegra #1
[ 5.255124] Hardware name: jetson_tx1 (DT)
[ 5.255125] Call trace:
[ 5.255132] [<ffffffc0000893ac>] dump_backtrace+0x0/0xe8
[ 5.255136] [<ffffffc000089858>] show_stack+0x14/0x1c
[ 5.255140] [<ffffffc00036cde0>] __dump_stack+0x20/0x28
[ 5.255142] [<ffffffc00036ce84>] dump_stack+0x9c/0xd8
[ 5.255145] [<ffffffc0000a4920>] panic+0xfc/0x274
[ 5.255148] [<ffffffc000b3049c>] kernel_init+0xdc/0xe8
[ 5.255150] [<ffffffc000084790>] ret_from_fork+0x10/0x40
[ 5.255155] CPU0: stopping
[ 5.255158] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.38-tegra #1
[ 5.255159] Hardware name: jetson_tx1 (DT)
[ 5.255160] Call trace:
[ 5.255164] [<ffffffc0000893ac>] dump_backtrace+0x0/0xe8
[ 5.255167] [<ffffffc000089858>] show_stack+0x14/0x1c
[ 5.255170] [<ffffffc00036cde0>] __dump_stack+0x20/0x28
[ 5.255172] [<ffffffc00036ce84>] dump_stack+0x9c/0xd8
[ 5.255175] [<ffffffc00008eeb0>] ipi_cpu_stop+0x4c/0x70
[ 5.255177] [<ffffffc00008f63c>] handle_IPI+0x168/0x2b8
[ 5.255179] [<ffffffc000080bd4>] gic_handle_irq+0xa0/0xb8
[ 5.255181] [<ffffffc000083f44>] el1_irq+0x84/0x100
[ 5.255184] [<ffffffc00080d704>] cpuidle_enter+0x18/0x20
[ 5.255187] [<ffffffc0000e6758>] call_cpuidle+0x4c/0x58
[ 5.255189] [<ffffffc0000e6830>] cpuidle_idle_call+0xcc/0x120
[ 5.255192] [<ffffffc0000e6ae0>] cpu_idle_loop+0x25c/0x27c
[ 5.255194] [<ffffffc0000e6b10>] convert_prio+0x0/0x3c
[ 5.255196] [<ffffffc000b303b4>] rest_init+0x8c/0x98
[ 5.255200] [<ffffffc001175a7c>] start_kernel+0x2dc/0x2e4
[ 5.255201] [<0000000080b36000>] 0x80b36000
[ 5.255204] CPU2: stopping
[ 5.255207] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G W 4.4.38-tegra #1
[ 5.255208] Hardware name: jetson_tx1 (DT)
[ 5.255209] Call trace:
[ 5.255213] [<ffffffc0000893ac>] dump_backtrace+0x0/0xe8
[ 5.255216] [<ffffffc000089858>] show_stack+0x14/0x1c
[ 5.255218] [<ffffffc00036cde0>] __dump_stack+0x20/0x28
[ 5.255220] [<ffffffc00036ce84>] dump_stack+0x9c/0xd8
[ 5.255222] [<ffffffc00008eeb0>] ipi_cpu_stop+0x4c/0x70
[ 5.255225] [<ffffffc00008f63c>] handle_IPI+0x168/0x2b8
[ 5.255226] [<ffffffc000080bd4>] gic_handle_irq+0xa0/0xb8
[ 5.255228] [<ffffffc000083f44>] el1_irq+0x84/0x100
[ 5.255230] [<ffffffc00080d704>] cpuidle_enter+0x18/0x20
[ 5.255233] [<ffffffc0000e6758>] call_cpuidle+0x4c/0x58
[ 5.255236] [<ffffffc0000e6830>] cpuidle_idle_call+0xcc/0x120
[ 5.255238] [<ffffffc0000e6ae0>] cpu_idle_loop+0x25c/0x27c
[ 5.255240] [<ffffffc0000e6b10>] convert_prio+0x0/0x3c
[ 5.255243] [<ffffffc00008f1fc>] secondary_start_kernel+0x16c/0x178
[ 5.255244] [<0000000080080e8c>] 0x80080e8c
[ 5.259923] CPU1: stopping
[ 5.259927] CPU: 1 PID: 163 Comm: kworker/u8:4 Tainted: G W 4.4.38-tegra #1
[ 5.259928] Hardware name: jetson_tx1 (DT)
[ 5.259931] Workqueue: kmmcd mmc_rescan
[ 5.259932] Call trace:
[ 5.259936] [<ffffffc0000893ac>] dump_backtrace+0x0/0xe8
[ 5.259938] [<ffffffc000089858>] show_stack+0x14/0x1c
[ 5.259941] [<ffffffc00036cde0>] __dump_stack+0x20/0x28
[ 5.259943] [<ffffffc00036ce84>] dump_stack+0x9c/0xd8
[ 5.259945] [<ffffffc00008eeb0>] ipi_cpu_stop+0x4c/0x70
[ 5.259947] [<ffffffc00008f63c>] handle_IPI+0x168/0x2b8
[ 5.259949] [<ffffffc000080bd4>] gic_handle_irq+0xa0/0xb8
[ 5.259951] [<ffffffc000083f44>] el1_irq+0x84/0x100
[ 5.259954] [<ffffffc0000a9c40>] irq_exit+0x70/0xd0
[ 5.259957] [<ffffffc0000f7018>] __handle_domain_irq+0x88/0xac
[ 5.259958] [<ffffffc000080ba0>] gic_handle_irq+0x6c/0xb8
[ 5.259960] [<ffffffc000083f44>] el1_irq+0x84/0x100
[ 5.259962] [<ffffffc0000f5bcc>] vprintk_emit+0x450/0x4a8
[ 5.259964] [<ffffffc0000f5e0c>] vprintk_default+0x34/0x3c
[ 5.259965] [<ffffffc0000f47e4>] printk+0xb8/0xc4
[ 5.259969] [<ffffffc00081e858>] sdio_read_cis+0x1fc/0x2ac
[ 5.259972] [<ffffffc00081ea44>] sdio_read_common_cis+0x10/0x18
[ 5.259974] [<ffffffc00081cc2c>] mmc_sdio_init_card+0x2f4/0x464
[ 5.259977] [<ffffffc00081d4f4>] mmc_attach_sdio+0xb0/0x2b8
[ 5.259980] [<ffffffc0008139d4>] mmc_rescan_try_freq+0x48/0x7c
[ 5.259981] [<ffffffc0008144c8>] mmc_rescan+0x1e0/0x254
[ 5.259984] [<ffffffc0000bd9cc>] process_one_work+0x25c/0x438
[ 5.259987] [<ffffffc0000be038>] worker_thread+0x168/0x290
[ 5.259989] [<ffffffc0000c3b2c>] kthread+0xfc/0x104
[ 5.259992] [<ffffffc000084790>] ret_from_fork+0x10/0x40
[ 5.712503] Rebooting in 30 seconds.......
The mmcblk0: mmc1:aaaa SL08G 7.40 GiB is the 8GB SDCard I had inserted. So it seems to be recognised at the sdhci driver level.
Also the same SDCard works fine on a Jetson board.
Any ideas what the issue could be?
