Description
I’m migrating my YoloV3 and YoloV4 code from TensorRT 6 to TensorRT 7 and getting some errors on INT8 calibration.
Both YoloV3 and YoloV4 can infer with FP32 correctly but I infer YoloV3 with INT8 will get the warning like the image below and get the wrong output.
(yolo-det is a cutom layer)
When I inferring YoloV4 on with INT8 will get the ERROR and crash like the following image.
I’m using IInt8EntropyCalibrator. Is there any update of INT8 calibration?
Environment
TensorRT Version : 7.1.3
GPU Type : Jetson TX2 iGPU
Nvidia Driver Version :
CUDA Version : 10.2
CUDNN Version : 8
Operating System + Version : Ubuntu 18.04
Hi @jackgao0323,
Can you please share the verbose logs along with the model and script.
Hi @AakankshaS,
This is the verbose of the YoloV4 mode run on INT8.
This is the last part of verbose of the YoloV3 mode run on INT8.
Will it be better if I save the logs as a file? Sorry I can’t provide our model and script.
I have solved the problem of running YoloV3 model in INT8 mode. The reason is I using the wrong size to do the calibration, but I still got the same problem on my YoloV4 model. Any update of this question?
Sorry, I’m using Jetson NX not Jetson TX2.
I’ve shared my implementation of INT8 TensorRT yolov3/yolov4 models here: Demo #6: Using INT8 and DLA core.
I don’t see the same problem as what you’ve described. But I do see some significant accuracy (mAP) drop on the INT8 yolov4 engine (comparing to the FP16 engine).
Actually, my model is not the same as YoloV4. My model is more similar to Implement Yolo-LSTM (~+4-9 AP) for detection on Video with high mAP and without blinking issues · Issue #3114 · AlexeyAB/darknet · GitHub yolo_v3_tiny_pan3.cfg model (https://github.com/AlexeyAB/darknet/files/3580764/yolo_v3_tiny_pan3_aa_ae_mixup_scale_giou.cfg.txt).
I’m trying another workflow from Darknet->Pytorch->ONNX->TensorRT.
But I still get some problem when I use trtexec to convert the model from ONNX to TensorRT.
I got the error message like below.
ERROR: builtin_op_importers.cpp:2179 In function importPad:
[8] Assertion failed: inputs.at(1).is_weights()
Have you met this error before?
@jackgao0323 No, I don’t see such a problem when building TensorRT engines for the more regular yolov3/yolov4 models.
I wonder whether the problem is related to the use of “swish” activation. “Swish” is not directly supported by TensorRT, so you’ll likely need to implement it with a plugin.
@jkjung13 Thanks for your reply. The problem is not swish activation because I replace it with x * sigmoid(x). I think the problem is the maxpooling. Darknet have a “special” maxpooling padding, so I use a padding before the maxpooling.
x = torch.nn.functional.max_pool2d(torch.nn.functional.pad(x, (padding3, padding4, padding1, padding2), mode='replicate'),self.size, stride=self.stride)
I am wondering whether it have some limitations of the padding or not.
Hi @jackgao0323,
Apologies for delayed response,
Can you pls share your onnx model?
