Mlx5_core: Bad OP in XDPSQ
Can anyone explain this error log?
[Tue May 30 05:55:25 2023] ------------[ cut here ]------------
[Tue May 30 05:55:25 2023] netdevice: enp129s0f1np1: Bad OP in XDPSQ CQE: 0xd
[Tue May 30 05:55:25 2023] WARNING: CPU: 2 PID: 0 at drivers/net/ethernet/mellanox/mlx5/core/en/xdp.c:556 mlx5e_poll_xdpsq_cq+0x2c1/0x370 [mlx5_core]
[Tue May 30 05:55:25 2023] Modules linked in: tls ipmi_ssif binfmt_misc nls_ascii nls_cp437 vfat fat intel_rapl_msr intel_rapl_common amd64_edac edac_mce_amd kvm_amd kvm irqbypass ghash_clmulni_intel sha512_ssse3 sha512_generic aesni_intel crypto_simd cryptd rapl pcspkr ast drm_vram_helper drm_ttm_helper ttm drm_kms_helper i2c_algo_bit acpi_ipmi ccp sp5100_tco watchdog rng_core k10temp ipmi_si ipmi_devintf ipmi_msghandler joydev evdev acpi_cpufreq button sg drm fuse loop efi_pstore configfs efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic mlx5_ib ib_uverbs ib_core hid_generic usbhid hid sd_mod crc32_pclmul dm_mod crc32c_intel ahci xhci_pci libahci mlx5_core xhci_hcd libata nvme usbcore nvme_core t10_pi scsi_mod mlxfw psample crc64_rocksoft crc64 ptp crc_t10dif scsi_common crct10dif_generic i2c_piix4 pps_core usb_common crct10dif_pclmul crct10dif_common pci_hyperv_intf
[Tue May 30 05:55:25 2023] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 6.1.0-9-amd64 #1 Debian 6.1.27-1
[Tue May 30 05:55:25 2023] Hardware name: Supermicro AS -2014TP-HTR-ZC010/H12SST-PS, BIOS 2.4.V1 11/22/2022
[Tue May 30 05:55:25 2023] RIP: 0010:mlx5e_poll_xdpsq_cq+0x2c1/0x370 [mlx5_core]
[Tue May 30 05:55:25 2023] Code: 54 24 24 48 85 c0 8b 4c 24 20 4c 8b 44 24 10 4c 0f 44 ef 4c 89 c2 4c 89 ee 44 89 54 24 08 48 c7 c7 10 21 85 c0 e8 6f 2e 0e d1 <0f> 0b 41 0f b6 44 24 3f 44 8b 54 24 08 c0 e8 04 0f b6 c8 e9 82 39
[Tue May 30 05:55:25 2023] RSP: 0018:ffffbc7c800fcd80 EFLAGS: 00010286
[Tue May 30 05:55:25 2023] RAX: 0000000000000000 RBX: 0000000000000002 RCX: 0000000000000000
[Tue May 30 05:55:25 2023] RDX: 0000000000000103 RSI: ffffffff92b3fa66 RDI: 00000000ffffffff
[Tue May 30 05:55:25 2023] RBP: 0000000000000000 R08: 0000000000000000 R09: ffffbc7c800fcbf0
[Tue May 30 05:55:25 2023] R10: 0000000000000003 R11: ffffa00a4f11ac28 R12: ffff9fcb4b1d3000
[Tue May 30 05:55:25 2023] R13: ffff9fcb33640000 R14: ffff9fcb1ce64240 R15: ffff9fcb55e3d000
[Tue May 30 05:55:25 2023] FS: 0000000000000000(0000) GS:ffffa0094e080000(0000) knlGS:0000000000000000
[Tue May 30 05:55:25 2023] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[Tue May 30 05:55:25 2023] CR2: 00007fbfd5368f38 CR3: 00000001e4240000 CR4: 0000000000350ee0
[Tue May 30 05:55:25 2023] Call Trace:
[Tue May 30 05:55:25 2023] mlx5e_napi_poll+0x3c5/0x710 [mlx5_core]
[Tue May 30 05:55:25 2023] __napi_poll+0x2b/0x160
[Tue May 30 05:55:25 2023] net_rx_action+0x2a5/0x360
[Tue May 30 05:55:25 2023] __do_softirq+0xf0/0x2fe
[Tue May 30 05:55:25 2023] ? handle_edge_irq+0x9f/0x240
[Tue May 30 05:55:25 2023] __irq_exit_rcu+0xc7/0x130
[Tue May 30 05:55:25 2023] common_interrupt+0xb9/0xd0
[Tue May 30 05:55:25 2023] asm_common_interrupt+0x22/0x40
[Tue May 30 05:55:25 2023] RIP: 0010:cpuidle_enter_state+0xde/0x420
[Tue May 30 05:55:25 2023] Code: 00 00 31 ff e8 d3 a6 97 ff 45 84 ff 74 16 9c 58 0f 1f 40 00 f6 c4 02 0f 85 25 03 00 00 31 ff e8 c8 62 9e ff fb 0f 1f 44 00 00 <45> 85 f6 0f 88 85 01 00 00 49 63 d6 48 8d 04 52 48 8d 04 82 49 8d
[Tue May 30 05:55:25 2023] RSP: 0018:ffffbc7c801bfe90 EFLAGS: 00000246
[Tue May 30 05:55:25 2023] RAX: ffffa0094e080000 RBX: ffff9fcb31535400 RCX: 0000000000000000
[Tue May 30 05:55:25 2023] RDX: 0000000000000002 RSI: ffffffff92b3fa66 RDI: ffffffff92b18f95
[Tue May 30 05:55:25 2023] RBP: 0000000000000002 R08: 0000000000000002 R09: 000000003677d5f2
[Tue May 30 05:55:25 2023] R10: 0000000000000018 R11: 0000000000068637 R12: ffffffff933a9620
[Tue May 30 05:55:25 2023] R13: 00000a8a776498e0 R14: 0000000000000002 R15: 0000000000000000
[Tue May 30 05:55:25 2023] cpuidle_enter+0x29/0x40
[Tue May 30 05:55:25 2023] do_idle+0x20c/0x2b0
[Tue May 30 05:55:25 2023] cpu_startup_entry+0x19/0x20
[Tue May 30 05:55:25 2023] start_secondary+0x11a/0x140
[Tue May 30 05:55:25 2023] secondary_startup_64_no_verify+0xe5/0xeb
[Tue May 30 05:55:25 2023] —[ end trace 0000000000000000 ]—
hi gopinath
This warning mean there’s a MLX5_CQE_REQ_ERR(0xd) return from the card.
Follow this log should have the detail cqe information to show what error happened.
Please contact networking-support@nvidia.com for further investigate.
Thank you
Meng, Shi
