I have a “mobilenet” which I froze (pb). I tried to convert it to uff, but it complains about “Unsupported operation _FusedBatchNormV3” which sounds like is not supported in uff yet. So I am now trying pb->onnx. Unfortunately I am not having any better luck with that:
~/convertToONNX$ python3 -m tf2onnx.convert --input /home/xavier/convertToONNX/frozen_inference_graph.pb --inputs X:0 --outputs output:0 --output /home/xavier/convertToONNX/ssd-raccoonnet.onnx
2020-01-17 15:08:24.026031: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/tf2onnx-1.6.0-py3.6.egg/tf2onnx/verbose_logging.py:72: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
2020-01-17 15:08:27,830 - WARNING - From /usr/local/lib/python3.6/dist-packages/tf2onnx-1.6.0-py3.6.egg/tf2onnx/verbose_logging.py:72: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
2020-01-17 15:08:27.835344: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcuda.so.1
2020-01-17 15:08:27.839512: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-01-17 15:08:27.839677: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
name: Xavier major: 7 minor: 2 memoryClockRate(GHz): 1.377
pciBusID: 0000:00:00.0
2020-01-17 15:08:27.839736: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-01-17 15:08:27.841502: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-01-17 15:08:27.843120: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-01-17 15:08:27.843710: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-01-17 15:08:27.846533: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-01-17 15:08:27.848348: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-01-17 15:08:27.854380: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-01-17 15:08:27.854585: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-01-17 15:08:27.854780: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-01-17 15:08:27.854956: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-01-17 15:08:27.872648: W tensorflow/core/platform/profile_utils/cpu_utils.cc:98] Failed to find bogomips in /proc/cpuinfo; cannot determine CPU frequency
2020-01-17 15:08:27.873562: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x2f66c8f0 initialized for platform Host (this does not guarantee that XLA will be used). Devices:
2020-01-17 15:08:27.873644: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): Host, Default Version
2020-01-17 15:08:27.934881: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-01-17 15:08:27.935306: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x2f7a07b0 initialized for platform CUDA (this does not guarantee that XLA will be used). Devices:
2020-01-17 15:08:27.935435: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): Xavier, Compute Capability 7.2
2020-01-17 15:08:27.935901: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-01-17 15:08:27.936054: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2020-01-17 15:08:27.936110: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-01-17 15:08:27.936152: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-01-17 15:08:27.936190: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-01-17 15:08:27.936220: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-01-17 15:08:27.936250: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-01-17 15:08:27.936279: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-01-17 15:08:27.936311: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-01-17 15:08:27.936427: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-01-17 15:08:27.936568: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-01-17 15:08:27.936639: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-01-17 15:08:27.936699: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-01-17 15:08:28.648073: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-01-17 15:08:28.648189: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165] 0
2020-01-17 15:08:28.648230: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0: N
2020-01-17 15:08:28.648539: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-01-17 15:08:28.648741: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-01-17 15:08:28.648915: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 8514 MB memory) -> physical GPU (device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2)
File "/usr/lib/python3.6/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.6/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/local/lib/python3.6/dist-packages/tf2onnx-1.6.0-py3.6.egg/tf2onnx/convert.py", line 161, in <module>
File "/usr/local/lib/python3.6/dist-packages/tf2onnx-1.6.0-py3.6.egg/tf2onnx/convert.py", line 116, in main
File "/usr/local/lib/python3.6/dist-packages/tf2onnx-1.6.0-py3.6.egg/tf2onnx/loader.py", line 64, in from_graphdef
File "/usr/local/lib/python3.6/dist-packages/tf2onnx-1.6.0-py3.6.egg/tf2onnx/loader.py", line 37, in freeze_session
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/util/deprecation.py", line 324, in new_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/graph_util_impl.py", line 277, in convert_variables_to_constants
inference_graph = extract_sub_graph(input_graph_def, output_node_names)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/graph_util_impl.py", line 197, in extract_sub_graph
_assert_nodes_are_present(name_to_node, dest_nodes)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/graph_util_impl.py", line 152, in _assert_nodes_are_present
assert d in name_to_node, "%s is not in graph" % d
AssertionError: output is not in graph
any ideas?
