michtw
June 18, 2024, 2:55am
1
I have a custom carrier board with L4T 35.5.
Case 1
HDMI and hotplug is OK with HDMI cable plugged in before booting.
Case 2
If HDMI cable is not plugged in before booting but after boot completed,
the monitor shows nothing when plugged in HDMI cable.
This is /var/log/Xorg.0.log of Case 1 .
[ 19.038] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 19.038] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 19.038] (--) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[ 19.135] (--) NVIDIA(GPU-0): ViewSonic VX2476 Series (DFP-1): connected
[ 19.135] (--) NVIDIA(GPU-0): ViewSonic VX2476 Series (DFP-1): Internal TMDS
[ 19.135] (--) NVIDIA(GPU-0): ViewSonic VX2476 Series (DFP-1): 165.0 MHz maximum pixel clock
[ 21.338] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 21.338] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 21.338] (--) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[ 21.435] (--) NVIDIA(GPU-0): ViewSonic VX2476 Series (DFP-1): connected
[ 21.435] (--) NVIDIA(GPU-0): ViewSonic VX2476 Series (DFP-1): Internal TMDS
[ 21.435] (--) NVIDIA(GPU-0): ViewSonic VX2476 Series (DFP-1): 165.0 MHz maximum pixel clock
This is /var/log/Xorg.0.log of Case 2 .
[ 18.025] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 18.025] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 18.025] (--) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[ 18.036] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 18.036] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 18.036] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
The gdm3 was running in the Case 1 & Case 2 .
root@nano:~# ps x | grep gdm
1125 ? Ssl 0:00 /usr/sbin/gdm3
1139 ? Sl 0:00 gdm-session-worker [pam/gdm-autologin]
1494 tty2 Sl+ 0:00 /usr/lib/xorg/Xorg vt2 -displayfd 3 -auth /run/user/1000/gdm/Xauthority -background none -noreset -keeptty
-verbose 3
root@nano:~# lsmod | grep nvidia
nvidia_modeset 1093632 3
nvidia 1327104 7 nvidia_modeset
And GPIO3 PM.00 (HDMI hot plug detect) is low when plug in HDMI and high when unplug HDMI in Case 1 and Case 2 .
How can I get the GNOME desktop environment in Case 2 ?
dmesg-case1.txt (85.5 KB)
dmesg-case2.txt (85.4 KB)
Xorg.0.log-Case1.txt (19.4 KB)
Xorg.0.log-Case2.txt (20.0 KB)
Do you know that you have to configure device tree to make HDMI supported and hotplug supported…?
michtw
June 18, 2024, 3:45am
3
Yes, I know. I had already done that.
HDMI and hotplug functions are working well in my Case 1 .
我可能用中文問比較清楚一點…請問你的case1到底是測什麼?
請問你的hotplug有沒有用的判斷依據是什麼?
case1的xorg log看起來一直沒有螢幕connected. 請問檔名是不是寫錯了?
可以請你在螢幕有亮的狀況下跑xrandr然後把結果分享一下嗎?
michtw
June 18, 2024, 4:29am
5
抱歉,xorg log 檔名寫錯。 已更正。
Case 1: 開機前插著HDMI,可進入 GNOME 桌面,熱插拔 HDMI,螢幕可正常顯示。
Case 2: 開機時不插HDMI,開機完成後插入HDMI,螢幕無任何顯示,螢幕OSD顯示無訊號。熱插拔 HDMI,螢幕無任何顯示。
xrandr 結果稍後給。
請你用xrandr的結果判斷hotplug有沒有成功 不要用螢幕能不能顯示判斷.
michtw
June 18, 2024, 7:08am
7
0. 開機時不接HDMI
1. 開機完成後接上HDMI
a@nano:~$ export DISPLAY=:0
a@nano:~$ [ 52.918442] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[ 52.928247] ---[ end trace 335ab4ff5e8f8d6c ]---
a@nano:~$ xrandr
Screen 0: minimum 8 x 8, current 640 x 480, maximum 32767 x 32767
DP-0 disconnected primary (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
2. 插拔HDMI,螢幕無顯示
3. 先接上HDMI,然後再執行 xrandr
a@nano:~$ xrandr
DP-1 connected (normal left inverted right x axis y axis)
1920x1080 60.00 + 59.94 50.00
1680x1050 59.95
1600x1200 60.00
1600x900 60.00
1440x900 59.89
1400x1050 59.98
1280x1024 75.02 60.02
1280x960 60.00
1280x720 60.00 59.94 50.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
4. 螢幕可顯示 GNOME 桌面
5. 插拔HDMI,螢幕可顯示 GNOME 桌面
看起來的結論是完成第3步驟,也就是插著 HDMI 接著執行 xrandr ,接下來的 HDMI 就都可以正常顯示畫面。
只要你的xrandr結果還是DP-0/DP1 你現在用的就是DP mode. 你沒有做完我提到的這個
在這個狀況下Hotplug GPIO是在AUX mode下動作, 不是GPIO mode.
michtw
June 18, 2024, 8:18am
9
抱歉,我不知道 Hotplug GPIO AUX mode 跟 GPIO mode 是什麼意思。有文件可以看嗎?
我有做了底下2個步驟,“make HDMI supported and hotplug supported” 的意思是指這些嗎?
用 Jetson_Orin_NX_and_Orin_Nano_series_Pinmux_Config_Template 產生 Support HDMI dts.
Patch dts
--- a/tegra234-mb2-bct-scr-p3767-0000.dts
+++ b/tegra234-mb2-bct-scr-p3767-0000.dts
@@ -5,6 +5,11 @@
tfc {
+ reg@322 { /* GPIO_M_SCR_00_0 */
+ exclusion-info = <2>;
+ value = <0x38009696>;
--- a/Linux_for_Tegra/source/public/hardware/nvidia/platform/t23x/p3768/kernel-dts/cvb/tegra234-p3768-0000-a0.dtsi
+++ b/Linux_for_Tegra/source/public/hardware/nvidia/platform/t23x/p3768/kernel-dts/cvb/tegra234-p3768-0000-a0.dtsi
@@ -274,6 +274,7 @@
display@13800000 {
status = "okay";
+ os_gpio_hotplug_a = <&tegra_main_gpio TEGRA234_MAIN_GPIO(M, 0) GPIO_ACTIVE_HIGH>;
這裡先簡單說明一下
→ 你作的東西不夠, 這些東西不足夠讓display run in HDMI mode.
有四個東西要改, 你改了其中三個
pinmux → 這個其實沒做什麼 就是讓HDMI HPD pinmux in GPIO.
tegra234-mb2-bct-scr-p3767-0000.dts 這個是firewall setting
os_gpio_hotplug_a 這個是設定hotplug gpio
決定driver要跑HDMI mode還是DP mode是透過一個DCB image來決定. 寫在device tree裡面
我們已經提供好現成的 dtsi file-> tegra234-dcb-p3767-0000-hdmi.dtsi
你可以直接把你device tree裡面原本的 tegra234-dcb-p3767-0000-dp.dtsi替換成上面這個之後進行整機重燒即可
dcb相關文件:
https://docs.nvidia.com/jetson/archives/r35.5.0/DeveloperGuide/SD/Kernel/DisplayConfigurationAndBringUp/OrinDisplayconfig.html?highlight=dcb
michtw
June 18, 2024, 9:48am
11
照著你說的4個步驟修改後,HDMI功能正常了。謝謝。Thanks a lot.
system
Closed
July 2, 2024, 9:48am
12
