The sensor module is an FSM-IMX530, connected to a framos adapter, and then to our TX2.
After typing gst-launch-1.0 nvarguscamerasrc, the same result came up, with the Camera mode being 4.
GST_ARGUS: 2656 x 2304 FR = 54,000002 fps Duration = 18518518 ; Analog Gain range min 1,000000, max 251,188705; Exposure Range min 14000, max 660000000;
Tuning files about what? The data package that we received regarding the framos components does not have anything regarding any changeable settings. The only things I have changed are regarding the adapter, and none of those affect the lens or the sensor itself.
Again, I am getting the correct colours using the samples from the Jetson MMAPI, but those are not ideal for what we are looking to do.
the nvgstcapture-1.0 tool is setting the 2656x2304 resolution by default. That resolution selects binning mode that is not supported on the color version of the sensor. Please use a different resolution. I would suggest using an Argus sample like argus_camera or nvarguscamerasrc GStreamer plugin for further evaluation.
Thank you for your patience in this regard. After attempting to run gst-launch-1.0 nvarguscamerasrc sensor-mode=n ! nvoverlaysink -e, where n was selected to be one of the available sensor modes, only the one with the monochromatic camera result was the one working.
Also, I couldn’t find, or at least couldn’t get any of the Argus samples to work, aside from there not being any sample called just argus_camera in the argus directory of the Jetson MMAPI.
After the package has been installed, the sources for argus samples should be located in /usr/src/jetson_multimedia_api/argus and instructions for building them in /usr/src/jetson_multimedia_api/argus/README.txt.
Regarding nvarguscamerasrc, try specifying the resolution and format alongside the sensor mode. For example, command for mode 0 (5328x4608@12bit) would be
I already do have nvidia-l4t-jetson-multimedia-api. The only thing about Argus is the outdated README.txt, aside from the fact that it does not build correctly. It complains about missing JPEG_LIBRARY and JPEG_INCLUDE_DIR.
Attempting to run the command you mentioned prompts an error in the pipeline (file attached). Program was then killed with Ctrl + C.
It looks like argus sample build fails because libjpeg-dev dependency is missing. Required dependencies are listed in the README.txt in the chapter Requirements.
For reference, following commands were successfully used to install dependencies and build argus samples on a TX2
sudo apt install cmake build-essential pkg-config libx11-dev libgtk-3-dev libexpat1-dev libjpeg-dev libgstreamer1.0-dev
cp /usr/src/jetson-multimedia-api ~ && cd ~/jetson-multimedia-api/argus
mkdir build && cd build
cmake ..
make -j$(nproc)
sudo make install
The resulting binary is attached for reference. Note that the binary will only work on L4T 32.5.1. argus_camera.tar.gz (524.2 KB)
To fix the gstreamer pipeline error, try specifying fps and scaling down the images before displaying them
If you are working with high resolutions and nvoverlaysink, you may encounter a known error vid_rend: syncpoint wait timeout and a red screen.
To fix this, open the file /etc/X11/xorg.conf.t186_ref and add the following line to the Device section
