MPI mixing host and gpu devices with PGI accelerator
I have an MPI program running in CPU or GPU accelerated version. I would like to have some processes running on host CPUs and other processes running on GPUs. So I try to compile my program using -ta=nvidia,host and I call acc_set_device(–) with the argument 0 or 3 according to process rank.
But when I run the executable I get
Usage error: multiple calls to acc_set_device with different device types
Did I make any mistake or is it not allowed? If not, will it be allowed in a next version and what is a possibile workaround avoiding duplacting all my subroutines?
thanks
Francesco
Hi Francesco,
I think you’re meaning to call “acc_set_device_num” which sets the device number to use versus “acc_set_device” which sets the device type.
Hope this helps,
Mat
Hi Mat,
no, I would like to have:
  • n_1 MPI processes running on n_1 host cores
  • n_2 MPI processes running on n_2 devices
where n=n_1+n_2 is the toal amount of MPI processes.
Hence, I think I need to specify acc_set_device. So, I can avoid duplicating subroutines for host or device compilation and use the twofold compilation -ta=nvidia,host provided by PGI compiler.
Is it possible?
thanks,
Francesco
Hi Francesco,
The error above suggests that you are calling acc_set_device multiple times using different device types. You can use acc_set_device, but it can only be called once per MPI process.
Can you post an example of your code?
Thanks,
Mat
Hi Mat,
here a simplified test case, performing a vector addition:
main.F90
program vector_add_test
#ifdef _ACCEL
use accel_lib
#endif
use mpi
use storage
implicit none
call mpi_init(ierr)
call mpi_comm_rank(mpi_comm_world,n_rank,ierr)
call mpi_comm_size(mpi_comm_world,n_proc,ierr)
GPU = .false.
#ifdef _ACCEL
print*,'NEW n_rank,NCOREXNODE: ',n_rank,NCOREXNODE
if(mod(n_rank,NCOREXNODE) .lt. NGPUXNODE) then
  call acc_set_device(acc_device_nvidia)
  device_kind = acc_get_device()
  print*,'Selected device kind:  ',device_kind
  num_devices = acc_get_num_devices(acc_device_nvidia)
  print*,'Number of devices available: ',num_devices
  call acc_set_device_num(mod(n_rank,NCOREXNODE),acc_device_nvidia)
  print*,'n_rank: ',n_rank,' tries to set GPU: ',mod(n_rank,NCOREXNODE)
  my_device = acc_get_device_num(acc_device_nvidia)
  print*,'n_rank: ',n_rank,' is using device: ',my_device
  print*,'Set GPU to true for rank: ',n_rank
  GPU = .true.
else
  call acc_set_device(0)
endif
#endif
call MPI_BARRIER(MPI_COMM_WORLD,ierr)
print*,'ciao'
if(GPU) then ; n = n_long ; else ; n = n_short ; endif
call allocate_storage()
!allocate(a(n),b(n),c(n))
call random(a)  ;  call random(b)
if(GPU) then
print*,'updating device'
!$acc update device(a,b)
endif
call vector_add()
if(GPU) then
print*,'updating host'
!$acc update host(c)
endif
print*,'GPU?: ',GPU,' c(5): ',c(5)
call mpi_finalize(ierr)
end program vector_add_test
allocate_storage.f90
subroutine allocate_storage()
use storage
implicit none
integer :: i
end subroutine allocate_storage
storage.f90
module storage
use accel_lib
integer, parameter :: myk = kind(1.d0)
real(myk), allocatable, dimension(:) :: a,b,c
integer, parameter :: NCOREXNODE=12
integer, parameter :: NGPUXNODE=2
integer :: num_devices
integer(acc_device_kind) :: my_device,device_kind
integer :: n_long=1000,n_short=150,n
integer :: ierr,n_rank,n_proc
logical :: GPU
!$acc mirror(a,b,c)
end module storage
vector_add.f90
subroutine vector_add()
use storage
implicit none
integer :: i
!$acc region
do i=1,n
   c(i) = a(i) + b(i)
enddo
!$acc end region
end subroutine vector_add
I compile using:
mpif90 -ta=nvidia,cc20,cuda4.0,host storage.f90 allocate_storage.f90 main.F90 vector_add.f90
Every MPI process should select the device type (host or nvidia) and, in case of GPU, the device number. It is now set on a node with 12 cores and 2 GPUs: the first 2 use GPUs while the other 10 use CPUs.
The error at runtime is:
Another curious error. If I allocate without calling a subroutine but inserting allocate(a(n),b(n),c(n)) in the main program I cannot use the second GPU (even for GPU only runs) because the first one seems to be automatically initialized and I do not know how to avoid it.
thanks a lot,
Francesco
Hi Francesco,
This appears to be a problem with the “mirror” directive not being ignored in the host context. I have written a report (TPR#18352) and sent it to our engineers for further investigation.
If you remove the “mirror” and “update” directives, then the code works as expected. Hopefully you can use this as a work around until we get this fixed.
Thank you for the report!
Mat
