• Hardware Platform: Jetson and GPU
• DeepStream Version 5.0.1 (Python bindings)
• Issue Type( questions, new requirements, bugs): Question
Hi all,
I need to use MQTT to transmit the outputs of the different models running in my application based on DeepStream.
So far, I have created a function in a probe that is attached to the sink pad of the nvdosd element. That function is creating a new thread (so it does not block the pipeline during transmission), creates the payload and publish it.
That solution works fine but I was wondering how I could write an MQTT adapter for the nvds_msgapi protocol adaptor interface. I looked at the documentation, but there is not much information there.
Is there a simple example somewhere to get me started? All I found is this deepstream-4.0.1/sources/libs/mqtt_protocol_adaptor at master · Kwull/deepstream-4.0.1 · GitHub, but that repo only renamed the files of the Kafka adaptor.
Johan
