root@z:~# ifconfig can0
can0: flags=128<NOARP> mtu 16
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 110
root@z:~# sudo modprobe can
root@z:~# sudo modprobe can_raw
root@z:~# sudo modprobe mttcan
root@z:~# sudo ip link set can0 up type can bitrate 500000
[ 155.707132] mttcan c310000.mttcan can0: Bitrate set
[ 155.707360] mttcan_controller_config: ctrlmode 0
[ 155.707504] mttcan c310000.mttcan can0: Bitrate set
root@z:~# [ 155.924835] mttcan c310000.mttcan can0: entered error warning state
[ 155.925060] mttcan c310000.mttcan can0: entered error passive state
[ 155.925658] mttcan c310000.mttcan can0: entered bus off state
ip -details -statistics link show can0
5: can0: <NO-CARRIER,NOARP,UP,ECHO> mtu 16 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 10
link/can promiscuity 0 minmtu 0 maxmtu 0
can state BUS-OFF (berr-counter tx 248 rx 0) restart-ms 0
bitrate 500000 sample-point 0.870
tq 20 prop-seg 43 phase-seg1 43 phase-seg2 13 sjw 1 brp 1
mttcan: tseg1 2..255 tseg2 0..127 sjw 1..127 brp 1..511 brp_inc 1
mttcan: dtseg1 1..31 dtseg2 0..15 dsjw 1..15 dbrp 1..15 dbrp_inc 1
clock 50000000
re-started bus-errors arbit-lost error-warn error-pass bus-off
0 0 0 1 1 1 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
RX: bytes packets errors dropped missed mcast
24 3 0 0 0 0
TX: bytes packets errors dropped carrier collsns
0 0 0 0 0 0
Trying to enable can0, however, it always show as down on ip a and if i try putting it up, I get entered error passive state. Any idea?
Orin NX 8GB, DevKit carrier, 5.10.192-l4t-35.5.0+gdb857ecdbe10
clean boot and tried again:
root@z:~#
root@z:~# dmesg | grep can0
[ 7.984622] net can0: mttcan device registered (regs=00000000c05b4b29, irq=110)
[ 8.892604] mttcan c310000.mttcan can0: bit-timing not yet defined
[ 8.892768] mttcan c310000.mttcan can0: failed to open can device
[ 98.056529] mttcan c310000.mttcan can0: Bitrate set
[ 98.056764] mttcan_controller_config: ctrlmode 0
[ 98.056915] mttcan c310000.mttcan can0: Bitrate set
root@z:~# [ 98.580039] mttcan c310000.mttcan can0: entered error warning state
[ 98.580247] mttcan c310000.mttcan can0: entered error passive state
[ 98.580813] mttcan c310000.mttcan can0: entered bus off state
Hi robyawyx,
You issue is about it enters into bus-off state.
Can you share the block diagram of your connection for can0?
Do you use CAN transceiver in your setup?
Jetson Linux release: R35.5.0 JetPack release: 5.1.3
Im using Zubax GNSS 2.2: High-performance board-level positioning module with compass and barometric altimeter for robots and unmanned vehicles - GNSS 2 - Zubax Robotics with Zubax Babel https://files.zubax.com/products/com.zubax.babel/Zubax_Babel_Datasheet.pdf and the CAN Bus Header- J16
root@z:~# ip link set can0 type can bitrate 500000 dbitrate 2000000 berr-reporting on fd on
[ 2322.497232] mttcan c310000.mttcan can0: Bitrate set
root@z:~# ip link set up can0
[ 2323.817100] mttcan_controller_config: ctrlmode 30
[ 2323.817265] mttcan c310000.mttcan can0: Bitrate set
root@z:~# [ 2323.987051] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 2323.987252] mttcan c310000.mttcan can0: IR 0x8000000 PSR 0x71d
[ 2323.987464] mttcan c310000.mttcan can0: entered error warning state
[ 2323.987671] mttcan c310000.mttcan can0: entered error passive state
[ 2323.987866] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 2323.988040] mttcan c310000.mttcan can0: IR 0x9800000 PSR 0x77d
[ 2323.988241] mttcan c310000.mttcan can0: entered bus off state
[ 2323.988419] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 2323.988587] mttcan c310000.mttcan can0: IR 0xa000000 PSR 0x7e5
[ 2324.995457] mttcan_controller_config: ctrlmode 30
[ 2324.995652] mttcan c310000.mttcan can0: Bitrate set
[ 2324.995826] mttcan c310000.mttcan can0: wait for bus off seq
[ 2325.008085] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 2325.008267] mttcan c310000.mttcan can0: IR 0xa000000 PSR 0x70d
Ah. No, I’m not using a CAN transceiver. That might be the issue. Will update later
CAN transceiver is necessary for CAN transaction for transform CAN-TX/CAN-RX to CAN-H/CAN-L to communicate with your other CAN devices.
system
Closed
June 5, 2024, 4:29am
9
