multi-gpu and cudamemcpyasync
Greetings,
I am using 2 GPUs with pthreads. I am trying to use CudaMemcpyAsync from host to device for both of the GPUs (different CPU data) via cudaStreams but this doesn’t seem to work. The code works fine when I replace CudaMemcpyAsync with CudaMemcpy.
Can we use cudamemcpyasync with multi-GPUs? If so, what might be causing my problem? If not, why can’t we use asynchronous copies with more than 1 GPU? Thanks.
Uh, how are you managing contexts?
something akin to this (forgive me if there exists any mistakes in syntax)
for (int i = 0; i < TOTAL_GPU_NUM; i++)
pthread_create(… , func, …);
func()
cudaSetDevice(tid);
cudaStream_t stream1;
cudaStream_t stream2;
cudaStreamCreate(&stream1);
cudaStreamCreate(&stream2);
if (tid == 0) // GPU 0
  some_gpu_function_call(..., stream1);
  cudaMemcpyAsync(..., stream2);
else
In the above code, if I replace cudaMemcpyAsync with cudaMemcpy, everything works well.
func()
cudaSetDevice(tid);
else
You’re not managing contexts, then. CUDART supports one device per thread; you can’t do what you’re trying to do.
I am pretty confused by this. In another code that uses just one GPU, I managed to successfully use cudaMemcpyAsync…
e.g.
pthread_create(…, func1, …);
pthread_create(…, func2, …);
func1()
some_gpu_function_call(…, stream1);
cudaMemcpyAsync(…, stream2);
func2()
some other stuff
Why can I manage to get something like this to work but not the other? Do I need to create more CPU threads to get cudaMemcpyAsync working on multiGPUs?
e.g.
func1()
func2()
some other stuff
Sorry, I totally missed the pthread_create. You’re probably not using portable pinned memory for your host-side allocations; if you add that flag to cudaHostAlloc, that should make cudaMemcpyAsync work fine from all child threads.
I have identified my problem. I had been using cudaMallocHost for my host-side allocations. This worked fine for single GPU but not for multi-GPU. Allocating CPU memory with cudaHostAlloc and using the cudaHostAllocPortable flag did the trick. Thanks.
