Hi everyone,
I’m using a fortran 90 MPI code and I compile it with mpif90 under nvhpc-23.1. The first thing that I do is the following:
integer :: LOCAL_COMM
integer :: num_gpus, my_gpu
integer(kind=acc_device_kind) :: device_type
call MPI_INIT(ierr)
call mpi_comm_split_type(MPI_COMM_WORLD, MPI_COMM_TYPE_SHARED, 0, MPI_INFO_NULL, LOCAL_COMM, ierr)
call MPI_COMM_RANK(LOCAL_COMM, my_id, ierr )
call MPI_COMM_SIZE(MPI_COMM_WORLD, num_proc, ierr)
! OpenACC set device
if (my_id == 0) print*, "Using Multi-GPU OpenACC"
device_type = acc_get_device_type()
num_gpus = acc_get_num_devices(device_type)
call acc_set_device_num(my_id, device_type)
my_gpu = acc_get_device_num(device_type)
write(*,*) "CPU Rank ",my_id,": using GPU",my_gpu," of type ",device_type
This is done to ensure a 1 to 1 communication between the CPUs and the GPUs. This is done partially in the main code (main.f90) and in another subroutine used to initialize MPI. After that in another .f90 file I do the following:
SUBROUTINE kinetics
USE global_mod, ONLY: TFlame, NsMAX, num_zones, zones, MINi, MAXi, MINj, MAXj, MINk, MAXk
USE common_alloc
USE openacc
USE common_mpi, ONLY: my_gpu
INTEGER, VALUE :: B, i, j, k, l, ll, s, icomp
!$acc declare create(B, l, ll, s, icomp)
DOUBLE PRECISION, VALUE :: OM(NUMSP), Yi_ijk(NsMAX), Xir(NsMAX)
!$acc declare create(OM(:), Yi_ijk(:), Xir(:))
DOUBLE PRECISION, VALUE :: T_ijk, p_ijk, dens, Rgst,S_y, Wmix_ijk, D_hp,rho_ijk
!$acc declare create(T_ijk, p_ijk, dens, Rgst,S_y, Wmix_ijk, D_hp,rho_ijk)
DOUBLE PRECISION, VALUE :: VREAZ(1000)
!$acc declare create(VREAZ(:))
INTEGER, VALUE :: NsMAT
INTEGER, VALUE :: iR, CC, NUMDICOMP, ISPECIE
INTEGER, VALUE :: NUMDICOMPF, NUMDICOMPB, REV, TERZOCORPO
!$acc declare create(NsMAT, iR, CC, NUMDICOMP, ISPECIE, NUMDICOMPF, NUMDICOMPB, REV, TERZOCORPO)
DOUBLE PRECISION, VALUE :: Kchem, Kchem_B, PRODF, PRODB, KEQ
!$acc declare create(Kchem, Kchem_B, PRODF, PRODB, KEQ)
DOUBLE PRECISION, VALUE :: NIF, NIB, NII!, omF(NUMSP),omB(NUMSP)
!$acc declare create(NIF, NIB, NII)
DOUBLE PRECISION, VALUE :: SOMMAH,SOMMAS,TEM
DOUBLE PRECISION, VALUE :: app
!DOUBLE PRECISION, POINTER, CONTIGUOUS :: A_app(:,:)
DOUBLE PRECISION, VALUE :: Y(NsMAX)
!$acc declare create(SOMMAH,SOMMAS,TEM,app,Y(:))
DOUBLE PRECISION, VALUE :: tmpsum,tmpsum2
!$acc declare create(tmpsum,tmpsum2)
!$acc declare copyin(my_gpu)
!$acc update device(TFlame,NUMREAZ,NUMDISPREAZF,NUMDISPREAZB,FLAGREAZ,FLAGM,TAB1F,TAB3F,TAB1B,TAB3B,FORD3,MASS,RORD3,DHF,DSF,REACT_PLOG,TAB2,TAB2M,TROE,SRI,NUMDISPM,NUMSP,ALFAM)
!$acc parallel loop gang vector collapse(3) &
!$acc& private(i,j,k,s,iR,cc,dens,icomp,T_ijk,p_ijk,NsMAT,NUMDICOMPF,NUMDICOMPB,REV,TERZOCORPO,PRODF,PRODB,NUMDICOMP,ISPECIE,NIF,NIB,NII,tmpsum,tmpsum2) &
!$acc& reduction(+:S_y,tmpsum,tmpsum2) reduction(*:Yi_ijk(:),PRODF,PRODB,Kchem) &
!$acc& copyout(omega) copyin(p,T,NsMAX,Yi(:,:,:,:),num_zones,zones,MINi,MAXi,MINj,MAXj,MINk,MAXk,BBB,rho,my_gpu)
do k= MINk(BBB)-(Ghost-1), MAXk(BBB)+(Ghost-1)
do j= MINj(BBB)-(Ghost-1), MAXj(BBB)+(Ghost-1)
do i= MINi(BBB)-(Ghost-1), MAXi(BBB)+(Ghost-1)
if(i==3.and.j==34.and.k==1) then
if(my_gpu==1) then
print*, "I am GPU #",my_gpu,i,j,k
elseif (my_gpu==0) then
else
print*, "NO GPU"
endif
endif
end do ! Loop su i
end do ! Loop su j
end do ! Loop su k
!$acc update self(omega)
print*, "EXITING"
Basically, I just do nothing inside the loops except for the print. The issue is that when running the program with
mpirun -n 2 ./my_program
I found for the same value of i,j,k (that are the nodes of a CFD computational grid) that both GPUs are working on it, which is strange because a CPU should work on some i,j,k and the rest should be done by the other CPU. The same thing should be done by the GPUs. However, when running the code it prints me:
I am GPU # 1 3 34 1
EXITING
I am GPU # 0 3 34 1
EXITING
which means that on i=3, j=34 and k=1 both GPUs are calculating the CFD solution on it.
Thanks everybody in advance for help or any suggestion to how solve this problem.
