Multi-Threaded computation with OpenMP
I had created a very large program in Intel Visual Fortran, using OpenMP parallel directives. This program worked just fine, and I had verified that I can indeed use multiple threads.
I am now migrating the source code of this program into PGI Visual Fortran. The program builds fine, except that I never get multi-threaded computation. Instead, I always use a single thread out of the 32 available in my PC. I did enable OpenMP directives, I even tried giving a command line /Qopenmp, but nothing worked. I would be grateful if you could provide some insights on what may be wrong.
Again, this is a very large program, which I cannot share online, and which was working perfectly fine with Intel’s Compiler and OpenMP. It works fine with PGI VF, except that I can never get multi-thread execution. I am trying to run some demanding computations, and it takes forever if I use a single thread, so any help will be most welcome!
I wanted to add that I also tried a very small program with OpenMP, and it still does not work. I am attaching my code here (it includes a main routine, a module and a subroutine). The code is supposed to print on the screen the different numbers of the threads corresponding to each iteration of a parallel DO loop. While the Intel Visual Fortran build does print different thread numbers, 0-3 (I use 4 threads in this program), the PGI Visual Fortran build always prints a value of 0 for the thread, inside the parallel DO loop.
module arr1
implicit none
SAVE
real8,allocatable,dimension(:,:) :: array1
end module arr1
program paral1
use arr1
use omp_lib
implicit none
integer i1,ith,NCPU,i2
real
8 sum
NCPU = OMP_GET_NUM_PROCS ( ) ! this command prints the total number of processors (both physical and virtual)
write(101,*) 'NCPU = ',NCPU
NCPU = 4
CALL OMP_SET_NUM_THREADS(4)
allocate(array1(100,NCPU))
array1 = 0.d0
sum=0.d0
!$OMP PARALLEL PRIVATE(ith)
!$OMP DO
do i1 = 1,100
ith = omp_get_thread_num ( )
write(,) i1,‘thread’, ith
call sub1(i1,ith+1)
!$OMP CRITICAL
do i2 = 1,NCPU
sum = sum + array1(i1,i2)
end do !i2
!$OMP END CRITICAL
end do !i1
!$OMP END DO
!$OMP END PARALLEL
do i1 = 1,100
write(101,1001) i1, (array1(i1,ith),ith=1,NCPU)
end do !i1
write(,) ‘sum=’,sum
write(,) ‘hit enter to complete execution’
read(,)
1001 format(i3,32(1x,e8.3))
end program paral1
subroutine sub1(iel,ithr)
use arr1
use omp_lib
implicit none
integer iel,ithr
array1(iel,ithr) = 1.d0
end subroutine sub1
Hi IKoutromanos,
By default the PGI native OpenMP runtime will use a single thread. You need to set “OMP_NUM_THREAD” in the environment to the number of threads to use or compile with “-mp=allcores” to change the default to use all cores on a system.
For details on using OMP_NUM_THREADS please see: User's Guide :: PGI version 18.5 Documentation for x86 and NVIDIA Processors
For “-mp=allcores” please see: Reference Manual :: PGI version 18.5 Documentation for x86 and NVIDIA Processors
Hope this helps,
Mat
Hi Mat,
I apologize, but my program includes the following command:
Shouldn’t this set the number of threads to 4 for the next parallel region?
Hi iKoutromanos,
Appoligies that I missed that you have the omp_set_num_threads call. Yes, that should work.
I tested it on my Windows system and it worked fine. Perhaps your not compiling with the “-mp” flag enabled?
Here’s my output:
PGI$ pgfortran -mp test.f90 -Minfo=mp
paral1:
     35, Parallel region activated
     37, Parallel loop activated with static block schedule
     44, Begin critical section (__cs_unspc)
     46, End critical section (__cs_unspc)
     53, Barrier
     54, Parallel region terminated
PGI$ ./test.exe
            1 thread            0
            2 thread            0
           76 thread            3
           77 thread            3
           78 thread            3
           79 thread            3
           80 thread            3
           81 thread            3
           82 thread            3
           83 thread            3
           84 thread            3
           85 thread            3
           86 thread            3
           87 thread            3
           88 thread            3
           89 thread            3
           90 thread            3
           91 thread            3
           92 thread            3
           93 thread            3
           94 thread            3
           95 thread            3
           96 thread            3
           97 thread            3
           98 thread            3
           99 thread            3
          100 thread            3
           26 thread            1
... cut ...
           20 thread            0
           21 thread            0
           22 thread            0
           23 thread            0
           24 thread            0
           25 thread            0
 sum=    100.0000000000000
-Mat
No, this is not the problem. The “enable OpenMP directives” option is active. Could it be something else? Are there specific CPU models that PGI supports?
Incidentally, even your own output looks “funny”. It seems that the program almost exclusively uses thread 3, with very few iterations run by thread 0 and a single iteration run by thread 1.
That was just because the output was long so I cut it. All four threads were used.
We support all 64-bit x86 based systems and Power 8,9 CPUs. So I doubt that this is the problem.
Sorry, but I’m not sure what’s wrong. I doesn’t quite make sense.
Can you please post the compile flags used as seen from the project’s properties “Fortran->Command Line” top text box?
Thanks,
Mat
Mat,
Sorry, I did not notice that the output was truncated.
Here are my compile flags:
-Bstatic -Mbackslash -mp -I"c:\program files\pgi\win64\18.4\include" -I"C:\Program Files\PGI\Microsoft Open Tools 14\include" -I"C:\Program Files (x86)\Windows Kits\10\Include\shared" -I"C:\Program Files (x86)\Windows Kits\10\Include\um" -fast -Minform=warn
I wanted to mention (in case it matters) that I am currently using a trial version of the Professional edition, and that I also have installed PGI Community Edition in my PC.
That shouldn’t matter. The compilers are fully featured with the CE and trial license.
You compiler options look correct so I’m still perplexed why it works fine for me but not for you. I’ve tried from both from the command line shell and from within PVF and both work as expected.
Let’s add the flag “-Minfo=mp” to the compile. This will have the compiler show which loops it’s parallelizing and we can double check that OpenMP code is being generated. You need to look at the build report to see the output in PVF.
What might also be helpful, is to build and run the code from a command line shell in case there’s some type of misconfiguration in PVF.
Are there any other OpenMP environment variables set in your environment? In particular, OMP_THREAD_LIMIT? If so, then this would limit the number of threads in use.
-Mat
Mat,
What do you mean by “build report”? Are you referring to the “build log”?
If yes, then I attach it here.
PVF Build Log
Begin rebuild: clean project
Deleting intermediate and output files for project 'Example_OpenMP', configuration 'Release'
Compiling Project ...
..\module1.for
c:\program files\pgi\win64\18.4\bin\pgfortran.exe -Hx,123,8 -Hx,123,0x40000 -Hx,0,0x40000000 -Mx,0,0x40000000 -Hx,0,0x20000000 -Bstatic -Mbackslash -mp -Mfixed -I"c:\program files\pgi\win64\18.4\include" -I"C:\Program Files\PGI\Microsoft Open Tools 14\include" -I"C:\Program Files (x86)\Windows Kits\10\Include\shared" -I"C:\Program Files (x86)\Windows Kits\10\Include\um" -fast -Minform=warn -module "x64\Release" -o "x64\Release\module1.obj" -Minfo=mp -c "E:\VT-MultiPhys\Example_OpenMP\module1.for"
Command exit code: 0
..\Source1.for
c:\program files\pgi\win64\18.4\bin\pgfortran.exe -Hx,123,8 -Hx,123,0x40000 -Hx,0,0x40000000 -Mx,0,0x40000000 -Hx,0,0x20000000 -Bstatic -Mbackslash -mp -Mfixed -I"c:\program files\pgi\win64\18.4\include" -I"C:\Program Files\PGI\Microsoft Open Tools 14\include" -I"C:\Program Files (x86)\Windows Kits\10\Include\shared" -I"C:\Program Files (x86)\Windows Kits\10\Include\um" -fast -Minform=warn -module "x64\Release" -o "x64\Release\Source1.obj" -Minfo=mp -c "E:\VT-MultiPhys\Example_OpenMP\Source1.for"
..\sub1.for
c:\program files\pgi\win64\18.4\bin\pgfortran.exe -Hx,123,8 -Hx,123,0x40000 -Hx,0,0x40000000 -Mx,0,0x40000000 -Hx,0,0x20000000 -Bstatic -Mbackslash -mp -Mfixed -I"c:\program files\pgi\win64\18.4\include" -I"C:\Program Files\PGI\Microsoft Open Tools 14\include" -I"C:\Program Files (x86)\Windows Kits\10\Include\shared" -I"C:\Program Files (x86)\Windows Kits\10\Include\um" -fast -Minform=warn -module "x64\Release" -o "x64\Release\sub1.obj" -Minfo=mp -c "E:\VT-MultiPhys\Example_OpenMP\sub1.for"
Linking...
c:\program files\pgi\win64\18.4\bin\pgfortran.exe -Wl,/libpath:"c:\program files\pgi\win64\18.4\lib" -Wl,/libpath:"C:\Program Files\PGI\Microsoft Open Tools 14\lib\amd64" -Wl,/libpath:"C:\Program Files (x86)\Windows Kits\10\Lib\winv6.3\um\x64" -Yl,"C:\Program Files\PGI\Microsoft Open Tools 14\bin\amd64" -Bstatic -mp -o "E:\VT-MultiPhys\Example_OpenMP\Example_OpenMP\x64\Release\Example_OpenMP.exe" "x64\Release\module1.obj" "x64\Release\Source1.obj" "x64\Release\sub1.obj"
Example_OpenMP build succeeded.
=================================================================== \ \ I also built using the Command Line Shell, and it still has the same exact problem. That is, all iterations of the loop are executed by a single thread.
Yes, the build log.
In mine, I see the following output:
Command output: [paral1: 36, Parallel region activated 38, Parallel loop activated with static block schedule 45, Begin critical section (__cs_unspc) 47, End critical section (__cs_unspc) 54, Barrier 55, Parallel region terminated ]
But I don’t see a similar line in your build log. Meaning that the OpenMP code isn’t getting generated.
I do notice that your file has a “for” suffix meaning that Fixed format will be used. In this case, be sure that your “!$OMP” sentinels begin in the first column, else they wont be recognized. Or alternatively add “-Mfree” to use Free form.
-Mat
Mat,
You found the source of the problem! I was not aware that a fixed-form file requires placing the sentinels at the first column, and I was mistakenly having them at the 7th column. After placing the sentinels at the first column, the program runs normally, and the correct number of threads is used.
Thank you for all your help on this.
Yannis
Excellent! Glad it’s working.
