I created an application that has multiple CPU threads whereby each CPU Thread creates a separate stream in the same context on my GPU. I have a Tesla K20c. I’m using Windows 7 64 bit and Cuda 5.5.
Here is my code:
#include "gpuCode.cuh"
__global__ void kernelAddConstant1(int *g_a, const int b)
int idx = blockIdx.x * blockDim.x + threadIdx.x;
g_a[idx] += b;
for (int i = 0; i < 4000000.0; i++)
if (i%2 == 0)
g_a[idx] += 5;
else
g_a[idx] -= 5;
// a predicate that checks whether each array elemen is set to its index plus b
int correctResult(int *data, const int n, const int b)
for (int i = 0; i < n; i++)
if (data[i] != i + b)
return 0;
return 11;
int gpuDo()
cudaSetDevice(0);
cudaStream_t stream;
cudaStreamCreate( &stream );
int *a;
int *d_a;
unsigned int n;
unsigned int nbytes;
int b;
n = 2 * 8192/16;
nbytes = n * sizeof(int);
b = 7; // value by which the array is incremented
cudaHostAlloc( (void**)&a, nbytes, cudaHostAllocDefault ) ;
cudaMalloc((void **)&d_a, nbytes);
for (unsigned int i = 0; i < n; i++)
a[i] = i;
unsigned int nbytes_per_kernel = nbytes;
dim3 gpu_threads(128); // 128 threads per block
dim3 gpu_blocks(n / gpu_threads.x);
cudaMemsetAsync(d_a, 0, nbytes_per_kernel, stream);
cudaMemcpyAsync(d_a, a, nbytes_per_kernel, cudaMemcpyHostToDevice, stream);
kernelAddConstant1<<<gpu_blocks, gpu_threads, 0, stream>>>(d_a, b);
cudaMemcpyAsync(a, d_a, nbytes_per_kernel, cudaMemcpyDeviceToHost, stream);
cudaStreamSynchronize ( stream ) ;
cudaStreamDestroy(stream);
//cudaFree(d_a);
int bResult = correctResult(a, n, b);
//if (a)
//cudaFreeHost(a); // free CPU memory
return bResult;
void gpuEnd()
cudaDeviceReset();
When I leave cudaFree and cudaFreeHost commented out I achieve the following result:
This is perfect except that I have a memory leak because I’m not using cudaFree and cudaFreeHost. When I do use cudaFree and cudaFreeHost I get the following result:
This is bad. When using cudaFree some streams wait for others to finish first and some streams work asynchronously. I’m assuming this is because cudaFree is not asynchronous which is fine but that doesn’t explain why it sometimes works as in the first three kernels called but not at other times? If cudaFree is called but the GPU is already busy doing something else is it possible to have the CPU continue computing and let cudaFree occur automatically the first chance it gets? Is there another way to approach this issue? Thanks for any help you can give!
