I’ve noticed that if I open two identical CUDA IPC mappings back-to-back—each time allocating a fresh buffer but never closing the old handle—then subsequent access to the peer memory region through ld.volatile.global/st.volatile.global for certain ranks does not seem to have any effect.
Below is a pseudo code to illustrate the issue which I am facing:
struct Signal {...}; // some structure for barrier design
struct RankSignal { Signal* signals[8]};
// Called once before any kernel launches
static
void initialize_multi_gpu_barrier(RankSignals* sg__, Signal** self_sg__) {
int nRanks, myRank;
MPICHECK(MPI_Comm_rank(MPI_COMM_WORLD, &myRank));
MPICHECK(MPI_Comm_size(MPI_COMM_WORLD, &nRanks));
CUDACHECK(cudaSetDevice(myRank));
cudaIpcMemHandle_t self_data_handle;
cudaIpcMemHandle_t data_handles[8];
Signal* buffer;
CUDACHECK(cudaMalloc(&buffer, sizeof(Signal)));
CUDACHECK(cudaMemset(buffer, 0, sizeof(Signal)));
CUDACHECK(cudaIpcGetMemHandle(&self_data_handle, buffer));
MPICHECK(MPI_Allgather(/*sendbuf=*/&self_data_handle,
/*sendcount=*/sizeof(cudaIpcMemHandle_t),
/*send type=*/MPI_BYTE,
/*recvbuf=*/data_handles,
/*recvcount=*/sizeof(cudaIpcMemHandle_t),
/*recv type=*/MPI_BYTE,
MPI_COMM_WORLD));
Signal* ipc_ptrs[8];
for (int i = 0; i < nRanks; i++) {
if (i == myRank)
ipc_ptrs[i] = buffer;
else
CUDACHECK(cudaIpcOpenMemHandle((void**)&ipc_ptrs[i], data_handles[i],
cudaIpcMemLazyEnablePeerAccess));
sg__->signals[i] = ipc_ptrs[i];
(*self_sg__) = ipc_ptrs[myRank];
void finalize_multi_gpu_barrier(RankSignals* sg,
Signal* self_sg,
int myRank,
int nRanks) {
cudaDeviceSynchronize();
for (int r = 0; r < nRanks; ++r) {
if (r == myRank) continue;
CUDACHECK(cudaIpcCloseMemHandle(sg->signals[r]));
sg->signals[r] = nullptr;
CUDACHECK(cudaFree(self_sg));
sg->signals[myRank] = nullptr;
__global__ void some_kernel(...){
... some work (which does not write to global memory)
//write to Signal object across peers through st.volatile.global.u32
// read from Signal object, on the current GPU through
// ld.volatile.global.u32 --- waiting for peer GPUs to write to it -- in spin loop // <--- line 1----+
... some work (which does not write to global memory) |
// Later, before launching a compute kernel: |
void run_work() { |
// First set of work |
initialize_multi_gpu_barrier(...); |
launch some_kernel(...); |
// finalize_multi_gpu_barrier(...); // <---- line 2 |
// second set of work |
launch some_kernel(...); // ----------------------------------------------------------------------+
I am using onlyld.volatile.global and st.volatile.global to access peer memory. (I am not sure if that is the root cause of the problem). Based on the documentation of volatile:
The semantics of volatile operations are equivalent to a relaxed memory operation with system-scope.
Since, I am not concerned about work writing to global memory, I did not use any fence (__threadfence_system) or acquire.sys/release.sys. And the approach just works fine with the line withfinalize_mulit_gpu_barrier() included (line-2).
When I allocate shared buffers back to back without a deallocation (line -2) in between, the second kernel_launch has some visibility issue of certain writes made by peer GPUs to the shared buffer.
Say Rank 0’s GPU keeps spinning on a zero valued shared location, to which say Rank 2’s GPU surely made a write (the write of Rank 2 is not seen by Rank 0 and it keeps on seeing zero). [I am not sure about the semantics of the level at which the flushes happen with just st.volatile/ld.volatile. Is some stale value being read by GPU in Rank 0 from L1 cache? From volatile semantics, I don’t expect that to be the case. I am not sure of the flushing semantics of acquire.sys/release.sys or __threadfence_system() either, but using them does not seem to have any effect here either.]
Can opening a second IPC mapping (with a new cudaMalloc) without ever closing the first one lead to strange behavior of writes when I use the peer pointer? In other words, do I have to call cudaIpcCloseMemHandle() (and free the original buffer) before creating a new IPC mapping, even if the handles refer to completely separate allocations? Any confirmation or pointer to the right best practice would help!
For context, I am using only one barrier barrier_at_start with some modifications from the vLLM source code.
