I’m either doing something wrong or what I want is simply impossible.
There are two GPU’s in my system, each has a monitor connected to it and I simply want to use them as two displays as you would if they were both connected to either one of the GPU’s.
However, in xorg.conf I need to setup two screens and this second screen never shows up as usable if I goto “Display Configuration” it does however work for the login prompt but after login it just stays at a blank Xscreen.
Sure, I could get it to “work” with Xinerama as one big screen. But then I have just one screen, which makes applications maximize using the entire width of the screen and gaming with Steam/Wine impossible.
How do I set it up to drive two screens using two GPU’s?
