My CUDA program gives different results each time I compile it
Here’s my kernel function code. Every time I compile and run it, I get different results. Is there something wrong with my program?
#define MAX_THREAD_PER_BLOCK 396
#define MIN_BLOCK_PER_MULTIPROCESSOR 591
static const int SIZE = 2211;
static const int FN = 1;
static __device__ __forceinline__ void transGlobalFuncRes(double *result, double v, int index, int parentId) {
		result[index + parentId] = v +  get_linear_global_id();
__forceinline__ __global__ void func_186(double* param1, int param2) {
	transGlobalFuncRes(param1, 100, 20, param2);
__global__ __launch_bounds__(MAX_THREAD_PER_BLOCK, MIN_BLOCK_PER_MULTIPROCESSOR) void entry(const double input, double* result, double* oval, int* fence, ulong fptr, ushort2* ldst, const int deep) {
	int *X = (int*)malloc(sizeof(int) * FN);
    memset(X, 2333, sizeof(int) * FN);
	__syncthreads();
    int ind = 2;
    do {
		func_186<<<1, 1>>>((result), (get_linear_global_id()));
    while (ind--);
    free(X);
By the way, get_linear_global_id() is used to get the thread’s index in the entire thread grid.
The program writes some data into the result array, but I noticed that every time I recompile and run it, I get different results.
check failed with: index=60 absErr=100.0 relErr=1.0 data1=100.0 data2=0.0
The data in the result appeared to be of different values.
maybe some piece of code you haven’t shown is broken. Be sure to perform proper CUDA error checking (including on the device kernel call), and run your code with compute-sanitizer.
