I want to start developing with CUDA and thought it might be a good idea to write a small program (see below). The purpose of the program is to allocate a float variable on host-side and to modify it from within a CUDA kernel. Therefore I allocate a float on device side, copy the host value to the device value and pass the device memory to the kernel invocation. After calling the kernel, I copy the value from the device to the host.
Everything compiles fine, but when running the program, I get an error at the kernel invocation call (see below the code).
#include <stdlib.h>
#include <stdio.h>
#include <cuda_runtime.h>
void checkCUDAError(const char *msg)
cudaError_t err = cudaGetLastError();
if( cudaSuccess != err)
fprintf(stderr, "Error while %s: %s.\n", msg, cudaGetErrorString( err) );
exit(-1);
__global__ void myFirstKernel(float * ptr)
*ptr = 333;
int main(int argc, char * argv[])
float * h = (float*) malloc(sizeof(float));
float * d;
*h = 332.0f;
cudaMalloc((void**)&d, sizeof(float));
checkCUDAError("allocating device memory");
cudaMemcpy(d, h, sizeof(float), cudaMemcpyHostToDevice);
checkCUDAError("copying from host to device");
/* Output the unmodified result. */
printf("Unmodified: %f\n", *h);
/* Modify host value "h" by kernel. */
myFirstKernel<<< 2, 2 >>>(d);
checkCUDAError("calling kernel");
cudaThreadSynchronize();
checkCUDAError("synchronizing threads");
/* Copy modified data from device to host. */
cudaMemcpy(h, d, sizeof(float), cudaMemcpyDeviceToHost);
checkCUDAError("copying from device to host");
/* Output the result modified by the kernel */
printf("Modified: %f\n", *h);
/* Free memory */
cudaFree(d);
checkCUDAError("freeing device memory");
free(h);
return EXIT_SUCCESS;
I only have a GeForceGo7400 so I need to run in Emulation mode. Here is the compilation output on my Vista machine. As you can see, The kernel invocation fails:
C:\Users\kwk\Desktop\test>nvcc -deviceemu net.cu && a.exe
net.cu
tmpxft_00001758_00000000-3_net.cudafe1.cpp
tmpxft_00001758_00000000-7_net.ii
Unmodified: 332.000000
Error while calling kernel: unknown error.
