hi everybody,
I brought an used infiniband switch silverstorm 9024, the problem i have for now is i cannot find admin password and don’t know how to reset it.
here is my story:
1, I used serial cable connect to switch
8 data bits
no parity bits
1 stop bit
57.6K baud
Use VT100 emulation.
Flow control = XON/XOFF
2, I can see the boot processing on terminal, info like this:
Welcome to the SilverStorm 9024 DDR CLI. Type ‘list’ for the list of commands.
→ Switch Chip A System Image GUID:0x000XXXX
Switch Chip A Node GUID:0x000XXXX
[823c8088] sshd: ssh server listening on 0.0.0.0 port 22.
AnafaII Firmware Version 1.0.4 Built 2008/01/09 11:37
Switch online
tIouMonSw: Initialization passed, monitoring 1 local IB devices.
HTTP listening on 0.0.0.0 port 80.
HTTPS listening on 0.0.0.0 port 443.
W| 0 00:00:43.990B: Thread “csmLogThread” (0x819077a8)
MSG:WARNING|CHASSIS:swql9024-1 GUID=0x000XXXX|COND:#6 Power Sup
ply N+1 redundancy not available|FRU:Chassis|PN:900
A| 0 00:01:03.990B: Thread “cme” (0x81d31418)
Cmea: Power supply 1 has gone off-line!
W| 0 00:01:03.990B: Thread “csmLogThread” (0x819077a8)
MSG:WARNING|CHASSIS:swql9024-1 GUID=0x000|COND:#17 FRU stat
e changed from online to offline|FRU:Power Supply 1|PN:200662-000
NtpClient: ERROR getting the Time
error code is: : S_sntpcLib_TIMEOUT
3, I CAN NOT input anything on terminal, tried diffrent terminal software (putty, secureCRT, windows xp hyperterminal) same thing.
4, I got ip address of switch
5, I use IE connect to switch, it asked my password, i tried admin/adminpass, didn’t work, operator/operpass worked, but i have no right to do anything.
Till now, i think i have two ways to go,
1, try to create an admin role user from terminal but terminal didn’t take any input
2, try to recover admin password
but I have no idea how to do that, any help will be great appreciated.
