Hi all!
I came across a rather persistent problem with cudaMemcpy3D (or more likely, my understanding of it) while working on my thesis.
I want to copy a device Array of floats into a cudaArray. The device array contains linear voxel data.
When I first copy the divice Array to a host Array, the following code works:
[codebox]size_t brick_pitch = width * sizeof( cuda_voxel_t );
cudaPitchedPtr srcPtr = make_cudaPitchedPtr((void*)srcArray, brick_pitch, width, height);
cudaMemcpy3DParms copyParams = { 0 };
copyParams.dstArray = dstArray;
copyParams.dstPos = dstPos;
copyParams.extent = dstSize;
copyParams.srcPtr = srcPtr;
copyParams.kind = cudaMemcpyHostToDevice;
HVR_CUDA_SAFE_CALL( cudaMemcpy3D( ©Params ) );[/codebox]
But I want to Copy directly from device to device.
the following Code compiles and doesn’t crash, but produces artifacts when displayed:
int linSize = brick_pitch * height * depth;
cudaPitchedPtr srcPtr;
cudaExtent pitchedVolSize = make_cudaExtent(brick_pitch, width, height);
HVR_CUDA_SAFE_CALL(cudaMalloc3D(&srcPtr, pitchedVolSize));
cudaMemcpy( srcPtr.ptr, (void*)srcArray, linSize, cudaMemcpyDeviceToDevice );
copyParams.kind = cudaMemcpyDeviceToDevice;
cudaFree( srcPtr.ptr );[/codebox]
I realize that this can’t be the way to go, I also tried the cudaMallocPitch method, but that resulted in crashing at the cudaMemcpy3D line.
What I want to know is: How do I set up the pitchedPointer in Order to copy from a device array to a cudaArray?
thanks a lot!
