Title says it all for all the ASUS peep go grab them SoC and TPM updates.
They are a bit slow loading but both took first try and nodes are up serving load just fine.
Are you noticing any performance/stability changes?
stability is rock solid they are running 96% load pulling 70w+
I am going to run a few benchmarks once they finish their work. I keep pretty extensive benchmarks on the nodes so I’ll see what if I am getting any boosts, the updates make reference to performance enhancements so I’d be happy to see that
not seeing any major performance boost 2-4% across many of my model benchmarks which could easily be just being in a fresh clean state
Updated 10 hour ago, and reboot took FOREVER (XX~XXX minutes).
A minor nvidia driver update happened this week as well, which might help with stability.
A few days ago, I ended up in dependency h3|| due to an inadvertent driver update and had to reimage an ASUS GX10. The imaging process likely installed newer firmware from ASUS; however, the NVIDIA dash suggests that the July NVIDIA update to nvidia-580-580-159.03 is missing. Following recommended update process using the dash puts me in a repeating loop that forgoes this driver install. Any ideas for rectification? I would prefer not having to deal with dependency issues again.
Same thing. Installed it two times - one after another, and then simply ignored this update message.
Installer, maybe broken for now.
Is this new GX10 firmware a beta firmware?
