I have a simple question:
If all the threads within a block need to read the same position (k) of an array (a), should I use a shared variable (w) like this:
shared float w;
if (blockIdx.x == 0) w = a[k];
__syncthreads();
or, since I’m not writing into the array, can I do this without causing a bottleneck:
shared float w = a[k];
I would go with the first one, but I need to know for sure :)
