NIM does not support llama-3.1-8b-instruct and llama-3.1-70b-instruct on GH200 On-Prem deployment
NIM does not support llama-3.1-8b-instruct on GH200.
Below is the command I tried
docker run -it --rm \
    --gpus all \
    --shm-size=16GB \
    -e NGC_API_KEY \
    -v "$LOCAL_NIM_CACHE:/opt/nim/.cache" \
    -u $(id -u) \
    -p 8000:8000 \
    nvcr.io/nim/meta/llama-3.1-8b-instruct:latest
Error
The requested image's platform (linux/amd64) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
exec /opt/nvidia/nvidia_entrypoint.sh: exec format error
Also does not work with Llama3.1-70B
Status: Downloaded newer image for nvcr.io/nim/meta/llama-3.1-70b-instruct:latest
WARNING: The requested image's platform (linux/amd64) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
Machine Spec
Thu Nov 7 10:41:29 2024
| NVIDIA-SMI 550.90.12 Driver Version: 550.90.12 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GH200 480GB On | 00000000:DD:00.0 Off | 0 |
| N/A 31C P0 82W / 700W | 2MiB / 97871MiB | 0% Default |
| | | Disabled |
| Processes: |
| ID ID Usage |
| No running processes found |
Hi @sjbbihan, unfortunately NIM does not support deployment on ARM platforms at the moment, including Grace CPUs. We’re working to close this gap in future releases.
