I am trying to run this github GAN:
I am trying to run in CMD on Windows 10:
python test.py --ckpt checkpoint/StyleCariGAN/001000.pt --input_dir examples/samples --output_dir examples/results --invert_images
However, the following error occurs:
No CUDA runtime is found, using CUDA_HOME='C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2'
File "test.py", line 10, in <module>
from invert import *
File "C:\Users\nicol\StyleCariGAN\invert.py", line 12, in <module>
from exaggeration_model import StyleCariGAN
File "C:\Users\nicol\StyleCariGAN\exaggeration_model.py", line 7, in <module>
from model import PixelNorm, EqualLinear, ConstantInput, StyledConv, ToRGB, ExaggerationLayer
File "C:\Users\nicol\StyleCariGAN\model.py", line 13, in <module>
from op import FusedLeakyReLU, fused_leaky_relu, upfirdn2d
File "C:\Users\nicol\StyleCariGAN\op\__init__.py", line 1, in <module>
from .fused_act import FusedLeakyReLU, fused_leaky_relu
File "C:\Users\nicol\StyleCariGAN\op\fused_act.py", line 15, in <module>
os.path.join(module_path, "fused_bias_act_kernel.cu"),
File "C:\Users\nicol\AppData\Local\Programs\Python\Python37\lib\site-packages\torch\utils\cpp_extension.py", line 1136, in load
keep_intermediates=keep_intermediates)
File "C:\Users\nicol\AppData\Local\Programs\Python\Python37\lib\site-packages\torch\utils\cpp_extension.py", line 1347, in _jit_compile
is_standalone=is_standalone)
File "C:\Users\nicol\AppData\Local\Programs\Python\Python37\lib\site-packages\torch\utils\cpp_extension.py", line 1445, in _write_ninja_file_and_build_library
File "C:\Users\nicol\AppData\Local\Programs\Python\Python37\lib\site-packages\torch\utils\cpp_extension.py", line 1834, in _write_ninja_file_to_build_library
cuda_flags = common_cflags + COMMON_NVCC_FLAGS + _get_cuda_arch_flags()
File "C:\Users\nicol\AppData\Local\Programs\Python\Python37\lib\site-packages\torch\utils\cpp_extension.py", line 1606, in _get_cuda_arch_flags
arch_list[-1] += '+PTX'
IndexError: list index out of range
I believe the CUDA_HOME PATH is completely wrong, but do not know what to set it as…
I have all the required pip installs, and as previously mentioned, have both CUDA 10.2 and 11.5 toolkits from NVIDIA. I am also using an RTX 3080.
Thank you in advance! I’m trying very hard to get this working!
