Hi
Previously, I create Python virtual environment in my Jetson Orin Nano (my CUDA version is 11.4.315) by using torch = 2.1.0a0+41361538.nv23.06 and torchvision = 0.16.0+fbb4cc5. It can work well without any error both installation process and inference. After that try to do the same thing with docker, I pulled the l4t-tensorrt image:nvcr.io/nvidia/l4t-tensorrt:r8.5.2.2-devel
. My docker image is built successfully and torch.cuda.is_available() returned True after I installed torch, but when I installed torchvision I got this error: No CUDA runtime is found, using CUDA_HOME=‘/usr/local/cuda’
This is my code inside bash script to install torchvision:
sudo apt install -y libjpeg-dev zlib1g-dev
git clone https://github.com/pytorch/vision torchvision
cd /home/torch/torchvision
git checkout v0.16.0
python3 setup.py install --user
This is my DockerFile:
# Use NVIDIA L4T TensorRT image as the base
FROM nvcr.io/nvidia/l4t-tensorrt:r8.5.2.2-devel
# Avoid prompts from apt
ENV DEBIAN_FRONTEND=noninteractive
# Set CUDA paths
ENV CUDA_HOME=/usr/local/cuda
ENV PATH=/usr/local/cuda/bin:${PATH}
ENV LD_LIBRARY_PATH=/usr/local/cuda/lib64:${LD_LIBRARY_PATH}
# Set the working directory in the container
WORKDIR /usr/src/app
# Copy the Python script into the container
COPY setup_docker.sh /usr/src/app/setup_docker.sh
RUN chmod +x /usr/src/app/setup_docker.sh && /bin/bash /usr/src/app/setup_docker.sh
I guess my problem is CUDA paths setting …
How can I set the correct CUDA paths or do you have a complete DockerFile to setup and install torchvision with nvcr.io/nvidia/l4t-tensorrt:r8.5.2.2-devel ?
Thnaks
