Thank you for your reply, here are my answers:
1.(1)yes, im testing on DS6.2 with CUDA11.8;
(2)I can not use the libnvdsinfer_custom_impl_Yolo.so generated by DS6.2 with CUDA11.8, it will run with error, maybe because my driver version is too low. So i use the libnvdsinfer_custom_impl_Yolo.so generated by DS6.0 with CUDA11.4.
(3)It runs with wrong output, part 2 will show,.
(4)The running log with no error, i didint save logs and i have debuged many times, i can show new logs in part 2.
2.(1)Tried with symmetric_padding, i set 1 but no difference,.
(2)Here is the NvDsInferParseYolo.cpp
* Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
* Edited by Marcos Luciano
* https://www.github.com/marcoslucianops
#include "nvdsinfer_custom_impl.h"
#include "utils.h"
extern "C" bool
NvDsInferParseYolo(std::vector<NvDsInferLayerInfo> const& outputLayersInfo, NvDsInferNetworkInfo const& networkInfo,
NvDsInferParseDetectionParams const& detectionParams, std::vector<NvDsInferParseObjectInfo>& objectList);
extern "C" bool
NvDsInferParseYoloE(std::vector<NvDsInferLayerInfo> const& outputLayersInfo, NvDsInferNetworkInfo const& networkInfo,
static NvDsInferParseObjectInfo
convertBBox(const float& bx1, const float& by1, const float& bx2, const float& by2, const uint& netW, const uint& netH)
NvDsInferParseObjectInfo b;
float x1 = bx1;
float y1 = by1;
float x2 = bx2;
float y2 = by2;
x1 = clamp(x1, 0, netW);
y1 = clamp(y1, 0, netH);
x2 = clamp(x2, 0, netW);
y2 = clamp(y2, 0, netH);
b.left = x1;
b.width = clamp(x2 - x1, 0, netW);
b.top = y1;
b.height = clamp(y2 - y1, 0, netH);
return b;
static void
addBBoxProposal(const float bx1, const float by1, const float bx2, const float by2, const uint& netW, const uint& netH,
const int maxIndex, const float maxProb, std::vector<NvDsInferParseObjectInfo>& binfo)
NvDsInferParseObjectInfo bbi = convertBBox(bx1, by1, bx2, by2, netW, netH);
if (bbi.width < 1 || bbi.height < 1)
return;
bbi.detectionConfidence = maxProb;
bbi.classId = maxIndex;
binfo.push_back(bbi);
static std::vector<NvDsInferParseObjectInfo>
decodeTensorYolo(const float* boxes, const float* scores, const float* classes, const uint& outputSize, const uint& netW,
const uint& netH, const std::vector<float>& preclusterThreshold)
std::vector<NvDsInferParseObjectInfo> binfo;
for (uint b = 0; b < outputSize; ++b) {
float maxProb = scores[b];
int maxIndex = (int) classes[b];
std::cout << "Prop " << maxProb << std::endl;
std::cout << "Class " << maxIndex << std::endl;
std::cout << "Threshold " << preclusterThreshold[maxIndex] << std::endl;
//if (maxProb < preclusterThreshold[maxIndex])
// continue;
float bxc = boxes[b * 4 + 0];
float byc = boxes[b * 4 + 1];
float bw = boxes[b * 4 + 2];
float bh = boxes[b * 4 + 3];
float bx1 = bxc - bw / 2;
float by1 = byc - bh / 2;
float bx2 = bx1 + bw;
float by2 = by1 + bh;
std::cout << "Box " << "[" << bx1 << " " << by1 << " " << bx2 << " " << by2 << "]" <<std::endl;
addBBoxProposal(bx1, by1, bx2, by2, netW, netH, maxIndex, maxProb, binfo);
return binfo;
decodeTensorYoloE(const float* boxes, const float* scores, const float* classes, const uint& outputSize, const uint& netW,
continue;
float bx1 = boxes[b * 4 + 0];
float by1 = boxes[b * 4 + 1];
float bx2 = boxes[b * 4 + 2];
float by2 = boxes[b * 4 + 3];
return binfo;
static bool
NvDsInferParseCustomYolo(std::vector<NvDsInferLayerInfo> const& outputLayersInfo, NvDsInferNetworkInfo const& networkInfo,
if (outputLayersInfo.empty()) {
std::cerr << "ERROR: Could not find output layer in bbox parsing" << std::endl;
return false;
std::vector<NvDsInferParseObjectInfo> objects;
const NvDsInferLayerInfo& boxes = outputLayersInfo[0];
const NvDsInferLayerInfo& scores = outputLayersInfo[1];
const NvDsInferLayerInfo& classes = outputLayersInfo[2];
const uint outputSize = boxes.inferDims.d[0];
//std::cout << "outputSize " << outputSize << "\n";
std::vector<NvDsInferParseObjectInfo> outObjs = decodeTensorYolo((const float*) (boxes.buffer),
(const float*) (scores.buffer), (const float*) (classes.buffer), outputSize, networkInfo.width, networkInfo.height,
detectionParams.perClassPreclusterThreshold);
objects.insert(objects.end(), outObjs.begin(), outObjs.end());
objectList = objects;
return true;
static bool
NvDsInferParseCustomYoloE(std::vector<NvDsInferLayerInfo> const& outputLayersInfo, NvDsInferNetworkInfo const& networkInfo,
return false;
std::vector<NvDsInferParseObjectInfo> outObjs = decodeTensorYoloE((const float*) (boxes.buffer),
return true;
extern "C" bool
return NvDsInferParseCustomYolo(outputLayersInfo, networkInfo, detectionParams, objectList);
extern "C" bool
return NvDsInferParseCustomYoloE(outputLayersInfo, networkInfo, detectionParams, objectList);
CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE(NvDsInferParseYolo);
In last cpp, i changed code in function decodeTensorYolo like this :
// continue;
The log is blew:
Now playing : file:///opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/meeting_demo/test.mp4
In create_source_bin
index : 0
WARNING: Overriding infer-config batch-size (0) with number of sources (1)
Added elements to bin
Using file: dsmeeting_config.yml
INFO: infer_trtis_backend.cpp:218 TrtISBackend id:1 initialized model: Meeting_Person
Decodebin child added: source
(meeting_demo:45442): GLib-GObject-WARNING **: 09:07:51.029: g_object_set_is_valid_property: object class 'GstFileSrc' has no property named 'drop-on-latency'
Decodebin child added: decodebin0
Running...
Decodebin child added: qtdemux0
Decodebin child added: multiqueue0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
In cb_newpad
Prop 0
Class 0
Threshold 0.5
Box [-3.68488 -6.09062 9.25938 16.9058]
Prop 0
Class 0
Threshold 0.5
Box [0.257194 -3.61133 20.3475 15.6011]
Prop 0
Class 0
Threshold 0.5
Box [7.60119 -4.33493 31.6653 16.812]
Prop 0
Class 0
Threshold 0.5
Box [13.8528 -4.36356 42.1008 17.4075]
Prop 0
Class 0
Threshold 0.5
Box [19.4193 -3.64592 51.9924 17.6033]
Prop 0
Class 0
Threshold 0.5
Box [26.2744 -3.11224 58.982 16.0277]
....and so on
I found the score outputs are all 0! I dont konw why.
3.Thank you for your samples, im learning from them.
