No performance improvement for Tensorflow TensorRT model on converted on Jetsons Xavier NX
We are trying to convert a tensorflow Faster RCNN model from saved model format to TensortRT FP32/FP16.
We were able to successfully conver the models, however inference times did not show any improvements. We used the follow code to convert:
import tensorflow
from tensorflow.python.compiler.tensorrt import trt_convert as trt
tf_saved_model_dir = "./infer_model_512Imsize/saved_model"
converter = trt.TrtGraphConverter(input_saved_model_dir=tf_saved_model_dir,
                                  max_batch_size=1,
                                  max_workspace_size_bytes=4294965097,   # 4GB
                                  precision_mode='FP16',
                                  minimum_segment_size=3,
                                  is_dynamic_op=False,
                                  maximum_cached_engines=1,
                                  use_calibration=False)
converter.save("./trt_converted_models/FRCNN_FP16_512Imsize_100Proposals")
The inference times are:
  1. Tensorflow saved model - 136 ms
  2. TensorRT FP16 model - 143 ms
Thanks,
Regards,
Krishna
In TF-TRT, it fallback a TensorRT non-supported layer into TensorFlow implementation.
If the model frequently switches between TensorFlow and TensorRT, the data transfer overhead will be high.
You can find the support matrix of TF-TRT below:
This information is also available on the console during converting.
