Dear community members
Our distributor recently sent us a GRID K1 for testing. It was installed in a HPE Proliant DL380 Gen9 running VMWare 6.5.
I have installed vib driver Version 367.92 on the ESXi Host and enabled xORG service on it. The vBIOS Versions are shown below:
GRID K1, 0000:0D:00.0, 80.07.BE.00.02
GRID K1, 0000:0E:00.0, 80.07.BE.00.03
GRID K1, 0000:0F:00.0, 80.07.BE.00.05
GRID K1, 0000:10:00.0, 80.07.BE.00.04
Then I installed a new VM with Server 2012 R2 and Citrix VDA 7.13, connected it to our 7.8 Farm and published a Desktop on it. A k180q vGPU Profile was assigned to the VM. Also NVIDIA Driver 369.95 was installed.
NVIDIA-smi shows me that the VM is using the vGPU:
| NVIDIA-SMI 367.92 Driver Version: 367.92 |
| 0 GRID K1 On | 0000:0D:00.0 Off | N/A |
| N/A 32C P8 10W / 31W | 4074MiB / 4095MiB | 0% Default |
| 1 GRID K1 On | 0000:0E:00.0 Off | N/A |
| N/A 32C P8 10W / 31W | 10MiB / 4095MiB | 0% Default |
| 2 GRID K1 On | 0000:0F:00.0 Off | N/A |
| N/A 24C P8 10W / 31W | 9MiB / 4095MiB | 0% Default |
| 3 GRID K1 On | 0000:10:00.0 Off | N/A |
| N/A 28C P8 10W / 31W | 9MiB / 4095MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 2288891 C+G shv-117 4064MiB |
So far so good, I think until this point everything is set up properly (please correct me if I’m wrong).
Then I started to play with citrix policies, which is extremely difficult because there is no reference value for this. I found a Threat here in this forum from a guy who posted his best working settings. The performance got a little better, but I am still not satisfied with the visual performance…
I cannot see a real difference between a Citrix session with or without vGPU, except that it has DirectX and OpenGL support. The framerates with DirectX Benchmarks like Furmark or Unigine Valley are terrible…
I don’t really know whats wrong… and it doesn’t make sense to me buying one ore more GRID cards when there is no performance improvement.
Maybe you guys have some ideas or tipps for me.
Thank you very much, best regards
C3dy
