Howdy,
We just updated our license (and management daemon) to support version 18.5 from version 17.7 and now any type of compilation fails reporting “No such feature exists”.
Both client and server are running on Linux. I’ve verified that the license.dat file is in UNIX format.
$ pgfortran -acc -fastsse -O3 -ta=multicore -Minfo -c hello-world.f90
pgfortran: LICENSE MANAGER PROBLEM: Failed to checkout license
pgfortran: LICENSE MANAGER PROBLEM: No such feature exists.
Feature: pgfortran
License path: /share/apps/rc/software/PGI/18.5-GCC-6.4.0-2.28/license.dat:
FlexNet Licensing error:-5,147
The license file has the features:
pgi-prof-lin32 pgi-dbg-lin64 pgi-dbg-lin32 pghpf pgfortran \
This is what the license server reports:
14:47:40 (lmgrd) Started pgroupd (internet tcp_port 59002 pid 3240)
14:47:40 (pgroupd) FlexNet Licensing version v11.14.1.3 build 212549 x64_lsb
14:47:40 (pgroupd) SLOG: Summary LOG statistics is enabled.
14:47:40 (pgroupd) SLOG: FNPLS-INTERNAL-CKPT1
14:47:40 (pgroupd) SLOG: VM Status: 0
14:47:40 (pgroupd) Server started on lmgr.mydom for:
14:47:40 (pgroupd) PGI2018-532141 (consisting of: pgi-hpf-lin64
14:47:40 (pgroupd) pgi-f95-lin64 pgi-f77-lin64 pgi-cc-lin64
14:47:40 (pgroupd) pgi-cpp-lin64 pgi-gpp-lin64 pgi-hpf-lin32
14:47:40 (pgroupd) pgi-f95-lin32 pgi-f77-lin32 pgi-cc-lin32
14:47:40 (pgroupd) pgi-cpp-lin32 pgi-gpp-lin32 pgi-prof-lin64
14:47:40 (pgroupd) pgi-prof-lin32 pgi-dbg-lin64 pgi-dbg-lin32
14:47:40 (pgroupd) pghpf pgfortran pgcc
14:47:40 (pgroupd) pgc++ pgprof pgdbg)
14:47:40 (pgroupd) PGI-legacy-tools (consisting of: pgi-prof
14:47:40 (pgroupd) pgi-dbg pgi-dbg-gui) pgi-prof
14:47:40 (pgroupd) pgi-dbg pgi-dbg-gui pgi-hpf-lin64
14:47:40 (pgroupd) EXTERNAL FILTERS are OFF
14:47:40 (lmgrd) pgroupd using TCP-port 59002
14:47:40 (pgroupd) SLOG: Statistics Log Frequency is 240 minute(s).
14:47:40 (pgroupd) SLOG: TS update poll interval is 600 seconds.
14:47:40 (pgroupd) SLOG: Activation borrow reclaim percentage is 0.
14:47:40 (pgroupd) (@pgroupd-SLOG@) ===============================================
14:47:40 (pgroupd) (@pgroupd-SLOG@) === Vendor Daemon ===
14:47:40 (pgroupd) (@pgroupd-SLOG@) Vendor daemon: pgroupd
14:47:40 (pgroupd) (@pgroupd-SLOG@) Start-Date: Fri Jul 06 2018 14:47:40 CDT
14:47:40 (pgroupd) (@pgroupd-SLOG@) PID: 3240
14:47:40 (pgroupd) (@pgroupd-SLOG@) VD Version: v11.14.1.3 build 212549 x64_lsb ( build 212549 (ipv6))
14:47:40 (pgroupd) (@pgroupd-SLOG@) === Startup/Restart Info ===
14:47:40 (pgroupd) (@pgroupd-SLOG@) Options file used: None
14:47:40 (pgroupd) (@pgroupd-SLOG@) Is vendor daemon a CVD: No
14:47:40 (pgroupd) (@pgroupd-SLOG@) Is TS accessed: No
14:47:40 (pgroupd) (@pgroupd-SLOG@) TS accessed for feature load: -NA-
14:47:40 (pgroupd) (@pgroupd-SLOG@) Number of VD restarts since LS startup: 0
14:47:40 (pgroupd) (@pgroupd-SLOG@) === Network Info ===
14:47:40 (pgroupd) (@pgroupd-SLOG@) Listening port: 59002
14:47:40 (pgroupd) (@pgroupd-SLOG@) Daemon select timeout (in seconds): 1
14:47:40 (pgroupd) (@pgroupd-SLOG@) === Host Info ===
14:47:40 (pgroupd) (@pgroupd-SLOG@) Host used in license file: lmgr.mydom
14:47:40 (pgroupd) (@pgroupd-SLOG@) Running on Hypervisor: Not determined - treat as Physical
14:48:09 (pgroupd) TCP_NODELAY NOT enabled
14:48:50 (pgroupd) UNSUPPORTED: "pgfortran" (xxxx xxxx xxxx xxxx ) testuser (No such feature exists. (-5,346))
