• Hardware Platform: Jetson Xavier / Jetson Nano / GTX 1060 / RTX 3060Ti
• DeepStream Version: nvcr.io/nvidia/deepstream:6.0.1-triton, nvcr.io/nvidia/deepstream:6.1-triton
• JetPack Version: Jetpack4.6
• NVIDIA GPU Driver Version: 510.73.05
Based on deepstream-test1, I wrote code that can reproduce the bug.
In the deepstream_test1_app.c
file, the osd_sink_pad_buffer_probe
function has been changed as follows:
static GstPadProbeReturn
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
NvDsObjectMeta *obj_meta = NULL;
NvDsMetaList * l_frame = NULL;
NvDsMetaList * l_obj = NULL;
NvDsDisplayMeta *display_meta = NULL;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next) {
obj_meta = (NvDsObjectMeta *) (l_obj->data);
if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
printf("frame = %d, class vehicle, left = %f, top = %f , width = %f, height = %f\n",
frame_number, obj_meta->rect_params.left, obj_meta->rect_params.top,
obj_meta->rect_params.width, obj_meta->rect_params.height);
if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
printf("frame = %d, class person, left = %f, top = %f , width = %f, height = %f\n",
frame_number++;
return GST_PAD_PROBE_OK;
as well as the definition of pgie and sink elements:
pgie = gst_element_factory_make ("nvinferserver", "primary-nvinference-engine");
sink = gst_element_factory_make ("fakesink", "nvvideo-renderer");
File dstest1_pgie_config.txt
has been completely redone:
infer_config {
unique_id: 1
gpu_ids: 0
max_batch_size: 30
backend {
inputs: [ {
outputs: [
{name: "conv2d_bbox"},
{name: "conv2d_cov/Sigmoid"}
triton {
model_name: "Primary_Detector"
version: -1
model_repo {
root: "/models/"
log_level: 0
strict_model_config: true
preprocess {
network_format: MEDIA_FORMAT_NONE
tensor_order: TENSOR_ORDER_LINEAR
tensor_name: "input_1"
maintain_aspect_ratio: 0
frame_scaling_hw: FRAME_SCALING_HW_DEFAULT
frame_scaling_filter: 1
normalize {
scale_factor: 0.0039215697906911373
channel_offsets: [0, 0, 0]
postprocess {
detection {
num_detected_classes: 4
nms {
confidence_threshold: 0.5
iou_threshold: 0.3
topk : 4
extra {
copy_input_to_host_buffers: false
input_control {
process_mode: PROCESS_MODE_FULL_FRAME
interval: 0
docker-compose.yml
file was also added for tritonserver:
version: '3.9'
services:
triton_server:
restart: always
image: nvcr.io/nvidia/tritonserver:21.08-py3
container_name: triton_server
command: tritonserver --model-repository=/models/
volumes:
- ./models:/models
ports:
- "8001:8001"
- "8002:8002"
- "8003:8003"
deploy:
resources:
reservations:
devices:
- driver: nvidia
device_ids: [ '0' ]
capabilities: [ gpu ]
After docker-compose up -d
in the container logs, the model status was as follows:
| Model | Version | Status |
| Primary_Detector | 1 | READY |
Now you can run the code:
nohup ./deepstream-test1-app /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264 > 1.log
nohup ./deepstream-test1-app /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264 > 2.log
After running the code, both log files are the same and differ only in the startup time:
root@49511ef0114c:/deepstream-test1# diff 2.log 3.log
2c2
< 2022-06-13 14:43:47.455075: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
> 2022-06-13 14:44:05.381798: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
Now we change dstest1_pgie_config.txt
fragment from such:
model_repo {
root: "/models/"
log_level: 0
to such:
grpc {
url: "triton_server_address:8001"
Run the same code:
nohup ./deepstream-test1-app /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264 > 1_bug.log
nohup ./deepstream-test1-app /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264 > 2_bug.log
we get:
root@49511ef0114c:/deepstream-test1# diff 1_bug.log 2_bug.log
17,36c17,36
< frame = 3, class vehicle, left = 544.536987, top = 475.619720 , width = 53.425827, height = 48.065083
< frame = 3, class vehicle, left = 588.732971, top = 477.273010 , width = 61.471939, height = 50.111492
< frame = 3, class vehicle, left = 615.755188, top = 495.509369 , width = 104.406647, height = 78.806992
< frame = 3, class person, left = 299.444122, top = 455.046082 , width = 176.051331, height = 362.353668
< frame = 4, class vehicle, left = 545.431519, top = 474.418884 , width = 52.260040, height = 49.574074
< frame = 4, class vehicle, left = 594.631226, top = 477.946472 , width = 68.152817, height = 49.521412
< frame = 4, class vehicle, left = 614.145813, top = 497.648163 , width = 105.005493, height = 76.422791
< frame = 4, class person, left = 298.719238, top = 456.335510 , width = 173.643143, height = 355.677856
< frame = 5, class person, left = 310.979645, top = 454.690552 , width = 156.119980, height = 402.667847
< frame = 5, class vehicle, left = 619.035522, top = 495.053131 , width = 106.797638, height = 81.174263
< frame = 5, class vehicle, left = 592.023560, top = 475.581085 , width = 73.765594, height = 50.918362
< frame = 5, class person, left = 0.000000, top = 396.647644 , width = 200.781845, height = 568.117798
< frame = 6, class vehicle, left = 619.577271, top = 493.844086 , width = 103.672165, height = 80.190193
< frame = 6, class vehicle, left = 544.962708, top = 475.137756 , width = 56.897598, height = 49.003025
< frame = 6, class vehicle, left = 578.650452, top = 476.278503 , width = 71.975006, height = 52.033951
< frame = 6, class person, left = 300.859833, top = 456.766663 , width = 171.413467, height = 355.382233
< frame = 7, class person, left = 313.783081, top = 461.919189 , width = 152.786789, height = 366.220795
< frame = 7, class vehicle, left = 545.041809, top = 476.345398 , width = 54.747253, height = 48.391716
< frame = 7, class vehicle, left = 589.668335, top = 475.500732 , width = 68.211044, height = 52.685608
< frame = 7, class person, left = 0.000000, top = 398.737000 , width = 213.900055, height = 602.954346
> frame = 3, class vehicle, left = 612.738770, top = 495.958832 , width = 107.338440, height = 78.978500
> frame = 3, class person, left = 295.735687, top = 454.111176 , width = 178.626022, height = 367.075012
> frame = 3, class vehicle, left = 587.028992, top = 476.702850 , width = 67.797684, height = 50.701576
> frame = 3, class vehicle, left = 543.125977, top = 476.135437 , width = 54.326981, height = 48.317467
> frame = 4, class vehicle, left = 619.577271, top = 493.844086 , width = 103.672165, height = 80.190193
> frame = 4, class vehicle, left = 544.962708, top = 475.137756 , width = 56.897598, height = 49.003025
> frame = 4, class vehicle, left = 578.650452, top = 476.278503 , width = 71.975006, height = 52.033951
> frame = 4, class person, left = 300.859833, top = 456.766663 , width = 171.413467, height = 355.382233
> frame = 5, class vehicle, left = 544.536987, top = 475.619720 , width = 53.425827, height = 48.065083
> frame = 5, class vehicle, left = 588.732971, top = 477.273010 , width = 61.471939, height = 50.111492
> frame = 5, class vehicle, left = 615.755188, top = 495.509369 , width = 104.406647, height = 78.806992
> frame = 5, class person, left = 299.444122, top = 455.046082 , width = 176.051331, height = 362.353668
> frame = 6, class vehicle, left = 545.137085, top = 474.665344 , width = 56.423080, height = 50.258690
> frame = 6, class vehicle, left = 621.677185, top = 494.147034 , width = 110.575424, height = 84.068649
> frame = 6, class vehicle, left = 588.362183, top = 475.390350 , width = 70.541199, height = 52.784439
> frame = 6, class person, left = 0.000000, top = 396.102020 , width = 196.791916, height = 557.763489
> frame = 7, class person, left = 310.979645, top = 454.690552 , width = 156.119980, height = 402.667847
> frame = 7, class vehicle, left = 619.035522, top = 495.053131 , width = 106.797638, height = 81.174263
> frame = 7, class vehicle, left = 592.023560, top = 475.581085 , width = 73.765594, height = 50.918362
> frame = 7, class person, left = 0.000000, top = 396.647644 , width = 200.781845, height = 568.117798
41,55c41,56
etc ...
If we analyze the difference between the two files, we can notice that irrelevant data may come (for example, from previous frames), the order of the data is not deterministic, the data may be skipped or come twice:
source.tar.xz (12.8 MB)
