here is what i followed:
on a fresh ubuntu, i installed cuda 11.8. rebooted the system and verified using nvidia-smi
then i downloaded the cudnn_v8.9.7. file name: [Local Installer for Ubuntu20.04 x86_64 (Deb)]
This is how i installed cudnn
- open terminal
- navigate to downloaded folder
- copy and paste the following commands
sudo dpkg -i cudnn-local-repo-ubuntu2004-8.9.7.29_1.0-1_amd64.debsudo cp /var/cudnn-local-repo-*/cudnn-local-*keyring.gpg /usr/share/keyrings/sudo apt update
- check available versions of libcudnn8 for CUDA. copy and paste the following in terminal
sudo apt list libcudnn8it was 8.9.7.29-1+cuda11.8
- Install the runtime, developer library and code samples using these commands
sudo apt install libcudnn8=8.x.x.x-1+cudaX.Ysudo apt install libcudnn8-dev=8.x.x.x-1+cudaX.Ysudo apt install libcudnn8-samples=8.x.x.x-1+cudaX.Y
- reboot the system
Verification
- install the following libraries
sudo apt-get install libfreeimage3 libfreeimage-dev
- Copy the cuDNN samples to a writable path.
cp -r /usr/src/cudnn_samples_v8/ $HOME
- Go to the writable path.
cd $HOME/cudnn_samples_v8/mnistCUDNN
- Compile the mnistCUDNN sample.
make clean && make- Run the mnistCUDNN sample.
./mnistCUDNN.
the output i get is attached in screenshot. the test is not passed. what am i doing wrong
