I’ve got a double precision program which I want to run on a GPU. My actual graphic card is Nvidia GTS 250 with compute capability 1.1. When I run the program on GPU i Got:
Compute capability mismatch
File: C:\test.F
routine: test_routine
line: 270
device: 0 compute capability 1.1
driver: 3000
Available compute capability: 1.3(cubin) 1.3(ptx)
In this article I’ve read that
Double-precision requires compute capability 1.3, so any code with double-precision will only generate the 1.3 version.
And this would be fine, since when I compile the code I get:
CC 1.3 : 4 registers…
even if I set -ta=nvidia,cc11
But the next sentence in this article is:
As before, you can override this behavior by setting an explicit compute capability option on the command line, or by setting a single default compute capability in the siterc file.
So, should setting -ta=nvidia,cc11 or -Mcuda,cc11 should override this problem? In my case it does not, but I’m wondering do I have to buy a better graphic card, or is it possible to run this code on my actual GPU anyway?
