When encoding with WebRTC, we call NvVideoEncoder::setBitrate() to change the bitrate.
The process returns immediately up to the 3000th call, but after the 3001st call, it does not return at all (the number of times varies each time, but it is always approximately the same number).
It is as if the caller has deadlocked and does not return forever.
It takes about two hours for this to occur.
In that case, the following will appear in syslog.
May 17 10:12:23 Xavier-abc01 kernel: [56874.024250] host1x 13e10000.host1x: nvhost_get_syncpt: failed to find free syncpt
May 17 10:12:23 Xavier-abc01 kernel: [56874.024407] falcon 15380000.nvjpg: nvhost_get_syncpt_host_managed: failed to get syncpt
We are using the following version. This is the latest that can be raised with our hardware.
Currently have no further idea about it. Would need your help to share a test app so that we can try to replicate the issue on Xavier developer kit.
We couldn’t replicate it, but found the cause.
Because we invoked our application, which called NvVideoEncoder::setBitrate(), as an external process and didn’t consume its stdout buffer, the application stopped because of stdout buffer full.
In other words, we thought that the stdout buffer was filled by ‘cout’ in NvVideoEncoder::setBitrate().
We corrected our program to consume its stdout buffer.
After that, we can call NvVideoEncoder::setBitrate() as often we want.
