Not working correctly new () and malloc () inside the kernel, why?
global void gpu_test_malloc(int * a_t_size)
	int64 t_size=a_t_size[0];//in 40435848;
	void * t_void=NULL;
	label_test:
	t_void=malloc(t_size);
	if(t_void==NULL)
		t_size--;
		goto label_test;
	a_t_size[1]=t_size;//out 7674032
//test
int * host_mem=new int[2];
int * device_mem;
host_mem[0]=40435848;//need
cudaStatus=cudaMalloc(&device_mem,sizeof(int)*2);
if (cudaStatus != cudaSuccess)throw;
cudaStatus=cudaMemcpy(device_mem,host_mem,sizeof(int)*2,cudaMemcpyHostToDevice);
gpu_test_malloc<<<1,1>>>(device_mem);
cudaStatus=cudaDeviceSynchronize();
cudaStatus=cudaMemcpy(host_mem,device_mem,sizeof(int)*2,cudaMemcpyDeviceToHost);
host_mem[1]= 7674032
GTX Titan(driver 320.14)
Nsight 3.0.0.13123
CUDA 5.0
64bit,compute_30,sm_30
include “cuda_runtime.h”
include “device_launch_parameters.h”
include <stdio.h>
__int64 t_size=a_t_size[0];//40435848;
void * t_void=NULL;
label_test:
if(t_void==NULL)
	t_size--;
	goto label_test;
a_t_size[1]=t_size;
int main()
cudaError_t cudaStatus;
try
int * device_mem;
host_mem[0]=40435848;//это нужный мне объём
	cudaStatus=cudaFree(device_mem);
	return cudaStatus;
}catch(...)
	return cudaStatus;
GTX Titan(драва 335.23)
Nsight 3.2.2.13351
CUDA 5.5
64bit,compute_35,sm_35
The device side malloc() is a suballocator from a fixed size heap. Given that the kernel loop is continuously allocating memory, I suspect the backing heap is being exhausted. The size of the heap can be changed using the CUDA API :
cudaDeviceSetLimit(cudaLimitMallocHeapSize, size_t size)
. More information about device side malloc() can be obtained in the toolkit documentation : http://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#dynamic-global-memory-allocation-and-operations
