Hello, I am profiling RTX 4080 with nsys-ui version 23.1.2
Per User Guide — nsight-systems 2024.1 documentation, I expected to see both GPU VRAM bandwidth and CPU DRAM bandwidth.
But on my own profiling, under GPU metrics, there is only ‘DRAM Bandwidth’.
I am confused if this is GPU VRAM(which is also DRAM) or CPU DRAM.
hwilper
2
If you are on Nsys version 2023.1.2, you need to update to a newer version to get CPU counters.
Nsys 2024.1 is available from developer.nvidia.com/nsight-systems
I have now used 2024.1.1, there are noticeable added functionalities like python backtrace,
but still no ‘VRAM Bandwidth’, just ‘DRAM Bandwidth’.
Can I understand this as nsys is currently not accessing CPU counters and ‘DRAM Bandwidth’ refers to GPU VRAM bandwidth?
